problem with Linux Mint ISO
vanya16012018 40 Reputation points
2026-07-18T07:33:00.34+00:00
i'm facing this issue right now: i installed a Linux Mint ISO for a VM, and after the installation was done, it started again. i cancelled it after i checked the File Explorer, which was there in Quick Access or smth like that. anyways, i couldn't find it neither in the Downloads folder (which is where i installed the ISO), nor in Oracle VirtualBox after pressing "other" and trying to find it. i tried to delete it, but the button is just grayed out. can somebody help me??
Ramesh Srinivasan 87,860 Reputation points Independent Advisor
2026-07-18T09:38:25.2+00:00
Which file are you trying to delete? Are you trying to delete the virtual machine? If possible, post a screenshot of the screen you're referring to.
0 additional answers
