How to determine what process a taskbar icon invokes
Phillip Richcreek 995 Reputation points
2026-07-17T04:31:40.4966667+00:00
I have reason to believe that incepting a given taskbar icon does not invoke the process to which I assigned it.
Thanks for your help,
PR
DaveM121 931.2K Reputation points Independent Advisor
2026-07-17T05:13:32.2933333+00:00
If that is a taskbar icon you have created yourself, open File Explorer.
Paste this into the address bar and press Enter:
shell:User Pinned\Taskbar
In the resulting folder, you will find the icons you have pinned to the taskbar.
Right click an icon and select Properties.
On the resulting Properties dialog, in the Target box, you will find the process and any arguments associated to the Taskbar icon.
Senthil kumar 2,420 Reputation points
2026-07-17T04:50:51.4466667+00:00
Hi @Phillip Richcreek
Get-StartApps | Select Name, AppID
Name                                                 AppID
Thanks.
0 additional answers
