How to Undo a Linked Heading Style
Irenē Colthurst 25 Reputation points
2026-07-17T03:02:39.1833333+00:00
I am copy editing a manuscript. The last line of body text at the end of Chapter 28 has the heading used for chapter numbering applied to it. That style is also linked somehow to the heading style for the Chapter 29 heading on the next page. I try to apply the normal body text heading to the line of text, and both shrink to the size of body text.
I have already selected the checkbox in the settings to delink the heading styles. The problem remains. So, how do I actually delink the heading styles on these two types of text so I can apply their separate heading styles?
Xavier-D 13,110 Reputation points Microsoft External Staff Moderator
2026-07-17T07:47:19.3966667+00:00
Hello Irenē Colthurst
This may be happening because the last line of Chapter 28 and the Chapter 29 heading are still part of the same paragraph, even though they appear on separate lines or pages.
Here are what you can try:
  1. Go to Home and select Show/Hide to display the formatting marks. Check the symbol after the last line of Chapter 28. If you see a bent arrow instead of a paragraph mark**¶**, delete it and press Enter.
  2. Click anywhere in the body-text paragraph and apply your normal body-text style.
  3. Click in the Chapter 29 heading and apply the chapter-heading style.
The Disable linked styles setting does not separate text that belongs to the same paragraph, so both sections must first have their own paragraph marks.
If they are already separate paragraphs, select the affected body text, choose Home > Clear All Formatting, and then apply the correct body-text style again.
I hope this helps restore the correct formatting for both sections.
Feel free reply back to this post and update me on this issue, I'll be happy to help.
1 additional answer
  1. Stefan Blom 352.4K Reputation points MVP Volunteer Moderator
    2026-07-17T15:10:13.5366667+00:00
    [---] there was simply no formatting mark of any kind at the end of the line when I clicked the formatting view. But after adding the pilcrow to the body text line, I could apply the chapter heading to Chapter 29.
    Is there a manual page break that separates the two paragraphs? In that case, formatting may "spill over" onto the next page, unless you add a paragraph mark as well, by pressing Enter. This is an old limitation in Word.
    With nonprinting marks displayed, pressing Enter adds a pilcrow, as you said, and the pilcrow represents a paragraph mark.
