Office Home & Business 2021 activation. Product key redeemed in 2022. License no longer activates.
C.S 0 Reputation points
2026-07-17T02:39:42.98+00:00
I purchased Office Home & Business 2021 in October 2022. It has worked on this Mac for nearly three years. After restarting my computer, Word now says 'License Not Activated.' I still have the original purchase receipt and product key, but I don't know which Microsoft account the key was originally redeemed with. Can you locate the license and help me reactivate it?
Microsoft 365 and Office | Install, redeem, activate | For home | MacOS
EmilyS_726 29,390 Reputation points Volunteer Moderator
2026-07-17T16:14:47.3733333+00:00
I don't t think I explained well to you.
The issue is not about your 2021 license.
The issue is about your MacOS. You are running a MacOS version lower than 12, that's the problem. If you read the article I sent you in my last reply, on July 13th, Microsoft requires Mac devices to have updated digital certificates in order to keep Office products activated. However, this updated certificate can only work on MacOS 12 and above. Since yours is below 12, your device will not receive this important update, hence your Office product cannot be activated and will enter what it is now called "reduced functionality mode".
So your options are:
  1. Use web version via web browser.
  2. Use your license on a supported Mac device running MacOS 12 or above.
    3.Update your MacOS to 12 or above if the device supports it.
2 additional answers
  1. GsN5034 - IA 77,095 Reputation points Independent Advisor
    2026-07-17T03:16:21.4866667+00:00
    Hello, thank you for reaching out to Microsoft Q&A.
    You can sign in with each of your Microsoft accounts on the Services & Subscriptions page one by one to see which account your Office Home & Business 2021 license is linked to.
    https://account.microsoft.com/services
    Open an InPrivate/Incognito browser window and sign in with your accounts one at a time. Use a separate tab for each account and check which one shows the Office Home & Business 2021 license.
    Once you’ve identified the correct account, you can use the Office license removal tool to remove all previous traces of the Office license from your device and then reactivate it.
    How to remove Office license files on a Mac
    Let me know if you still need more help.
  2. EmilyS_726 29,390 Reputation points Volunteer Moderator
    2026-07-17T03:18:32.8833333+00:00
    What MacOS version are you using?
