Outlook for Mac does not display my inbox and folders page correctly.
Donald Koliha 30 Reputation points
2026-07-16T02:42:16+00:00
I was using Outlook (Legacy version) for my MacBook today without any issues whatsoever. However, when I opened Outlook this evening, the placement of items on the screen showed large gaps between the top menu line (Home-Organize-Tools) and the toolbar below it. Additionally, there is a similar large gap between the toolbar with all the icons (New Email - New Items - Delete - Reply - Forward, etc) and the "On My Computer" section that has all my mail folders and email messages.
I have compared every option for adjusting the screen size, display formatting, etc. to the Outlook (Legacy Version though earlier version) on my iMac Pro, and the settings between the two (MacBook Pro and iMac Pro) are identical. The unexpected and unwanted gaps on the MacBook's Outlook screen is making working on emails in Outlook tedious and frustrating. I cannot specifically blame this on having a newer version of Outlook on the MacBook, but this peculiar behavior just started late today, and I cannot determine the cause, or the solution. The version of Outlook on the MacBook is Version 16.111.5 (26071215). Here is a screen shot of Outlook on the MacBook Pro's screen that illustrates the problem:
Odd gaps in Outlook
Any help or insight on how to resolve this issue would be greatly appreciated!
<Signature has been removed>
Outlook | MacOS | Legacy Outlook for Mac | For home
Victor1-V 13,025 Reputation points Microsoft External Staff Moderator
2026-07-16T07:37:40.0533333+00:00
Hi Donald Koliha,
I understand that the large blank spaces appeared suddenly in Legacy Outlook for Mac, while the same Outlook version displays normally on another Mac. Since you have already compared the available display and formatting settings, this does not appear to be caused by a standard Outlook view option.
Please note that this is a user-to-user forum, so contributors cannot examine Outlook diagnostic data.
First, select Help > Check for Updates and install any available Office update. If Outlook is already current or the layout remains unchanged, select Help > Contact Support in Outlook and include the screenshot, Outlook version 16.111.5, and the detail that the behavior occurs only on the MacBook Pro. This will allow the Outlook support team to review the application logs and the unexpected interface rendering. For reference, see Update Office for Mac automatically | Microsoft Support and Contact support within Outlook for Mac | Microsoft Support
Because your screenshot shows On My Computer folders, I would not recommend removing the Outlook profile or reinstalling Office before backing up any locally stored messages.
I hope the Outlook support team can help identify what is causing this layout on the affected Mac.
0 additional answers
