Hello Kirbster,
I tried to follow the steps you took running Dism, which there is no need for unless sfc fails with errors.
I rebooted then ran an offline scan:
The computer ran the offline scan and rebooted back to the Desktop as it should. Why you consistently have issues with Defender, I have no idea what is going on with your system and what you do.
Regards,
Johnny
