Storage account and blob container not found
94267623 20 Reputation points
2026-07-14T13:29:52.42+00:00
Good day , I am pretty new to Azure and trying to play around -- How to you add a storage account and blob container ?
Azure Storage
Azure Storage
Globally unique resources that provide access to data management services and serve as the parent namespace for the services.
AI answer
2026-07-14T13:30:09.25+00:00
To add a storage account and then create a blob container in the Azure portal:
  1. Sign in to the Azure portal.
  2. Search for Storage accounts and select it.
  3. Select + Create.
  4. On Create a storage account, set:
    • Subscription: select the subscription to use.
    • Resource group: select an existing group or create a new one.
    • Storage account name: enter a unique name. It must be 3 to 24 characters and use lowercase letters and numbers only.
    • Region: select a region.
    • Performance: Standard.
    • Redundancy: leave the default unless a different option is needed.
  5. Select Review + Create, then Create.
  6. After deployment finishes, open the new storage account.
  7. In the storage account menu, under Data storage, select Containers.
  8. Select + Container.
  9. Enter a container name. The name must be lowercase, start with a letter or number, can include letters, numbers, and hyphens, and must be 3 to 63 characters long.
  10. Set Anonymous access level or Public access level. The recommended/default setting is Private (no anonymous access).
  11. Select Create.
If Data storage is not visible, search for Containers directly in the storage account, because the portal layout can vary.
2 additional answers
  1. Andreas Baumgarten 132.9K Reputation points MVP Volunteer Moderator
    2026-07-14T13:37:15.85+00:00
    Hi @94267623 ,
    to create an Azure Storage Account please follow this step-by-step guide: Create an Azure storage account
    to create a container in the created Azure Storage Account follow this steüp-by-step guide: Quickstart: Upload, download, and list blobs with the Azure portal
    (If the reply was helpful please don't forget to upvote and/or accept as answer, thank you)
    Regards
    Andreas Baumgarten
  2. 94267623 20 Reputation points
    2026-07-16T06:12:59.3733333+00:00
    Thank you guys ! got it going !
