Hi LD Lissandra,
There is no supported registry modification to extend ReFS metadata remapping timeouts, you must address the root cause of these storage saturation issues rather than trying to bypass safety mechanisms designed to protect your data integrity. To diagnose whether the bottleneck lies within your storage fabric or host bus adapter, I recommend auditing your Event Viewer logs, specifically within the Microsoft-Windows-StorPort/Operational channel, for Event IDs 129 or 153. If the underlying hardware is functioning correctly, you can stabilize the environment by applying Hyper-V Storage Quality of Service policies to throttle aggressive I/O bursts and ensuring your ReFS volumes are formatted with a 64KB allocation unit size, which significantly optimizes metadata handling for heavy virtual disk workloads.
Hope this answer has brought you some useful information. If it did, please hit “accept answer”. Should you have any questions, feel free to leave a comment.
VPHAN
