Startups: Companies that are in their initial stages of business and typically developing a business model and seeking financing.
The application is not starting because the sign-in flow for Microsoft for Startups requires a personal consumer Microsoft account. Work, school, and company-domain email accounts aren't accepted for the sign-up steps. That matches the behavior described: signing in with a work account redirects into Azure Portal instead of starting the Microsoft for Startups application flow.
Supported next steps:
- Start the application again from the Microsoft for Startups page at https://startups.microsoft.com and select Get started or Get started now.
- When redirected to Microsoft sign-in, use a personal consumer Microsoft account.
- If there is no Microsoft account for the desired personal email, select Create an account.
- If an investor referral code exists, enter the 10-character code; otherwise choose Continue without a code.
- After account creation/setup, allow up to 24 hours for the credit balance to fully update.
- After submission, application review is typically completed within three business days and the decision is sent by email.
What to expect if the application starts correctly:
- During review, Azure Portal can show $1,000 in starter credits.
- On first sign-in, a welcome modal appears and a yellow banner indicates the application is under review.
- After approval, expanded benefits and credits become available.
For help with application review, approval status, onboarding, Azure credit activation issues, incorrect sponsorship offer type, or owner-account corrections, Microsoft for Startups Program Support handles those issues. The documented support path is:
- If the Azure account is already set up, submit a support request through the Azure Portal.
- For program-specific application questions, use https://aka.ms/startuphelp-mfs-portal.
- In Azure Portal, the documented path is Program support and then select the category matching the issue.
