HOME 2024 EXCEL QUESTION - CAN'T PRINT OR SAVE MY WORK?
tmd3 0 Reputation points
2026-07-13T16:15:29.4633333+00:00
PURCHASED A NEW IMAC 2024. PREVIOUS WORK ON A DELL TOWER COMPUTER 2014. UPLOADED FROM AN EXISTING USB THUMB DRIVE MY EXISTING EXCEL WORK SHEETS VIA A USB HUB. ALL GOOD AS I BEGAN UPDATING MY WORK SHEETS. UPON COMPLETION, I SAVED WITHIN EXCEL. TRIED TO PRINT MY WORK, NO LUCK. TRIED TO SAVE MY WORK AND GOT A MESSAGE SHOULD ACTIVATE EXCEL OR RISK ALL MY UPDATES. ALSO SAID PRINTING NOT SUPPORTED.
QUITE CONFUSED, ANY SUGGESTIONS?
Microsoft 365 and Office | Excel | Other | MacOS
    2026-07-13T16:15:45.32+00:00
    The symptoms match an Office activation problem on the new Mac. In this state, Excel can show Save/Save As limitations and printing not supported messages.
    Try this in order:
    1. In Excel on the Mac, use the menu bar and select Excel > Sign Out.
    2. Restart the iMac.
    3. Open Excel again and complete the sign-in/activation prompt for Office Home 2024.
      • One accepted resolution for the same Home 2024 on Mac scenario was that Office 2024 had not yet been activated.
    4. After activation, test saving again:
      • Click Save on the Quick Access Toolbar, or press Ctrl+S.
      • If it is the first save for that file, use Save As, choose a folder, enter a file name, and click Save.
    5. Test printing:
      • Click File > Print or press Ctrl+P.
      • Check whether the preview appears and then print.
    If saving still fails after activation, check the file location and permissions:
    1. Save the workbook to a local folder on the iMac instead of the USB thumb drive or a hub-connected device.
    2. Excel needs Read, Write, Modify, and Delete permissions to the folder where the file is being saved.
    3. If a save process is interrupted, Excel documentation recommends saving to an alternative drive.
    If printing still fails after activation, isolate whether the issue is the workbook, Office, or the printer:
    1. In Excel, create a new file with File > New.
    2. Type a few words and try to print it.
      • If the new file prints, the problem is likely in the original workbook.
    3. Try printing from another Mac app such as Notes.
      • If Notes prints successfully, the issue may be with the Office installation.
      • If Notes also fails, the issue is more likely the printer driver or printer configuration.
    If Excel on the Mac still will not save after activation, a moderator-recommended fix for a similar Mac case was to remove the old Office version and then reinstall the new one.
