Power Query and Power Pivot can't refresh data that contains data sources from my organization's Sharepoint
Pang 0 Reputation points
2026-07-13T03:02:15.7433333+00:00
Originally, I created a dashboard in excel using power query and power pivot, which get data source from the organization's sharepoint, which works fine until 9 July 2026 ,My file unable to sign in to refresh data and there is a notification as shown in the picture. How to fix it?
Screenshot 2026-07-13 094839
Screenshot 2026-07-13 095117
Microsoft 365 and Office | SharePoint | Other | Windows
  1. Sagan Sundesha 0 Reputation points
    2026-07-17T04:35:46.52+00:00
    Same problem we are facing in our organization , it was working fine untill last 2 week and suddenly getting this error.We are unable to connect to sharepoint folder from excel using powerquery.
    2026-07-13T03:57:09.6933333+00:00
    Hi Pang
    According to my research based on the messages shown, the issue appears while Excel is attempting to connect to the SharePoint data source. The screenshots reference Microsoft sign-in pages and authentication-related URLs, which may indicate a problem with the authentication process or stored credentials used for the SharePoint connection
    You can try the following:
    • In Excel, go to Data > Get Data > Data Source Settings.
    • Select the SharePoint connection and choose Clear Permissions.
    • Close Excel completely.
    • Open Excel again and sign in with the Microsoft 365 work account that has access to the SharePoint site.
    • Try refreshing the queries again.
    For your information: Refresh an external data connection in Excel | Microsoft Support
    If the issue persists, could you please share some information:
    • Which version of Excel is being used (File > Account > About Excel)?
    • Does the issue affect only one user, or all users who refresh this workbook?
    • Can the affected account access the source SharePoint site directly in a web browser?
    • Did the issue start after a password change, MFA change, Conditional Access policy change, or Office update?
    For your reference: Power Query Refresh Fails with SharePoint 500 Internal Server Error - Microsoft Q&A
    I hope this information helps and look forward to your response!
