An Azure service that provides a cloud content delivery network with threat protection.
Front Door: Unavailable (Unplanned) : Unavailable Backends (Unplanned)
hi,
we are getting daily lots of these health events in Resource Health from our front door instance.
example:
At Friday, 10 July 2026 at 3:14:42 pm CEST, the Azure monitoring system received the following information regarding your Cdn profile: One or more of your Front Door/CDN profiles backends are responding with errors to health probes. The backends associated with this Front Door/CDN profile are not responding to health probes with the expected status. Recommended Steps
- The detected Origin Health event represents an aggregate health status across all your origins. Please check 'Origin Health Percentage' metrics in Metrics blade (Monitoring section) to identify the specific origin that is experiencing issues.
- Review 'Origin Health Percentage' metrics in metrics and logs documentation
- Origin groups with single origin will cause higher false positive as health probes are not effective for single origins. Please follow best practices to disable health probes.
- If you are experiencing problems you believe are caused by Azure, contact support .
Most of these appear to be false positives — the site works fine and metrics show no issue.
However, one event on 9 July 2026 correlated with a real, user-facing incident, which is the focus of this question:
What we've ruled out for this specific event:
- No deployment/release at that time
- No regional Azure Service Health incidents for our region
we found out in one of our app service instance Availability and Performance possible cause. instance was replaced around the same time. screenshots attached.
Open questions:
- Given the volume of daily alerts, is there a way to distinguish, at scale, false-positive probe noise from genuine origin impact like the 9 July event — without manually cross-referencing instance history each time?
- Can Microsoft identify what triggered the 9 July instance replacement (auto-heal, platform maintenance, host issue)?
- Is there a known behavior where in-flight requests to an instance being drained/replaced stall near the ~60s timeout instead of failing fast or being retried on the new instance?
- We're unable to submit a support ticket — the portal detects this open health event and redirects us to "resolve this first." Is there a way around this, or can a moderator escalate directly?
