MY SURFACE NOT STARTING WITHOUT POWER CABLE
VINOD KUMAR RAHI 0 Reputation points
2026-07-10T10:27:48.2466667+00:00
My Surface Pro 11 will not turn on even with a full battery unless I have it plugged in. Sometime after weeks it will start on batterey itself and perform good for few days, but again same problem persist, no one responds to service requests too from microsoft. Is there any problem with after sales service of surface pro. My surface pro is new and rarely used but getting such problems is unusual.
Surface | Surface Laptop | Power and battery
  1. Carl-L 21,480 Reputation points Microsoft External Staff Moderator
    2026-07-15T13:15:25.6366667+00:00
    Hello VINOD KUMAR RAHI,
    Welcome to Microsoft Q&A forum.
    May I know if you have had the chance to check on the AI assistant suggestion yet? If you did, may I know how it goes?
    Before we proceed further, may I know what happens if you start it while plugged in and then unplug it?
    I'm waiting for your reply.
  2. AI answer
    2026-07-10T10:29:27.57+00:00
    There is no known general problem with Surface Pro after-sales service in the provided information, but the behavior described indicates a hardware or firmware issue that normal troubleshooting may not fully resolve.
    Try the following steps that are supported for Surface devices:
    1. Basic power and charging checks
      • Disconnect all accessories (USB devices, SD card, external monitor, Surface Dock, Type Cover, etc.).
      • Connect the original Surface power supply and charge for at least 15 minutes.
      • Close and reopen the Type Cover or lid, then press the Power button to turn it on.
      • If the LED on the Surface Connect charger is blinking, flashing, or off, follow the guidance in What to do if your Surface power supply or charger doesn’t work.
    2. Force shutdown and restart
      • Press and hold the Power button for 20 seconds, then release it.
      • Wait 10 seconds.
      • Press the Power button again to turn Surface on.
    3. Update Surface Pro 11 drivers and firmware manually Intermittent battery/power behavior on Surface Pro 11 can be caused by driver/firmware issues.
      • Shut down Surface completely.
      • Hold the Power button for 20 seconds, then release and wait 10 seconds.
      • Turn it back on.
      • Go to Microsoft’s official Surface Drivers page.
      • Download the Surface Pro 11 Driver and Firmware package (.msi).
      • Install the package.
      • Restart Surface.
    4. If Surface still will not reliably start on battery
      • If the device does not turn on at all without the power cable after these steps, it likely needs hardware service (battery, power circuitry, or mainboard).
      • Use Device service and repairs to check warranty and submit a service order.
      • If online service requests are not being answered, use the options in the support article to either:
        • Send to Microsoft: prepare the device for shipping, check warranty, create a service order, and print a shipping label.
        • Find in-person support: use an in-person service center where available.
        • Self-repair: only if technically experienced and with the right tools, using official replaceable components and guides.
    If the device is new and under warranty and still shows this behavior after driver/firmware updates and power resets, the supported path is repair or replacement through Microsoft’s service options.
