Maybe shrinking drive C by 1 MB would work, preferably in disk management? :)
Unable to fix error 0xc0000017 on advanced startup due to missing EFI System Partition on Win 10 PC
I wanted to upgrade to Windows 11 but I needed to change my BIOS mode from legacy to UEFI. However when I went to advanced startup to follow the instructions on how to change it I got the 0xc0000017 error when I clicked on the command prompt. I basically had the same issue the user had from [this](https://learn.microsoft.com/en-us/answers/questions/2338992/having-trouble-fixing-error-0xc0000017-(advanced-s) post up to the most recent response which still didn't get resolved. I also want to point out that when I typed >bcdedit/delete {badmemory}, I didn't get an error but an access denied message which is below here.
C:\windows\system32>bcdedit/enum all
Windows Boot Manager
identifier {bootmgr}
device partition=U:
description Windows Boot Manager
locale en-US
inherit {globalsettings}
default {current}
resumeobject {57615d88-34bd-11eb-b184-1803733bf2bc}
displayorder {current}
toolsdisplayorder {memdiag}
timeout 30
Windows Boot Loader
identifier {current}
device partition=C:
path \windows\system32\winload.exe
description Windows 10
locale en-US
inherit {bootloadersettings}
recoverysequence {57615d8a-34bd-11eb-b184-1803733bf2bc}
displaymessageoverride CommandPrompt
recoveryenabled Yes
allowedinmemorysettings 0x15000075
osdevice partition=C:
systemroot \windows
nx OptIn
bootmenupolicy Standard
Windows Boot Loader
identifier {57615d8a-34bd-11eb-b184-1803733bf2bc}
device ramdisk=[C:]\Recovery\WindowsRE\Winre.wim,{57615d8b-34bd-11eb-b184-1803733bf2bc}
description Windows Recovery Environment
locale en-us
displaymessage Recovery
osdevice ramdisk=[C:]\Recovery\WindowsRE\Winre.wim,{57615d8b-34bd-11eb-b184-1803733bf2bc}
systemroot \windows
nx OptIn
winpe Yes
Resume from Hibernate
identifier {57615d88-34bd-11eb-b184-1803733bf2bc}
device partition=C:
path \windows\system32\winresume.exe
description Windows Resume Application
locale en-US
inherit {resumeloadersettings}
recoveryenabled Yes
filedevice partition=C:
filepath \hiberfil.sys
debugoptionenabled No
Windows Memory Tester
identifier {memdiag}
device partition=U:
path \boot\memtest.exe
description Windows Memory Diagnostic
locale en-US
badmemoryaccess Yes
EMS Settings
identifier {emssettings}
bootems No
Debugger Settings
identifier {dbgsettings}
debugtype Local
RAM Defects
identifier {badmemory}
Global Settings
identifier {globalsettings}
inherit {dbgsettings}
{emssettings}
Boot Loader Settings
identifier {bootloadersettings}
{hypervisorsettings}
Hypervisor Settings
identifier {hypervisorsettings}
hypervisordebugtype Serial
hypervisordebugport 1
hypervisorbaudrate 115200
Resume Loader Settings
identifier {resumeloadersettings}
Device options
identifier {57615d8b-34bd-11eb-b184-1803733bf2bc}
ramdisksdidevice partition=C:
ramdisksdipath \Recovery\WindowsRE\boot.sdi
C:\windows\system32>bcdedit/delete {badmemory}
This entry cannot be deleted unless the /f switch is specified on the command
line. Run bcdedit /? for more information.
Access is denied.
Then I followed the rest of the instructions on the post then used the >list partition command, no EFI system partition was located on any of the disks. When I opened Disk Management there isn't a EFI located and I don't know what to do to get the EFI back. Screenshot (394).png
- Please run
msinfo32.exe, and click System Summary. Resize the columns in the right pane to make the entries visible, and post a screenshot. - Open Command Prompt admin and run this command:
mbr2gpt /validate /disk:2 /allowFullOS
Post the output.
4 additional answers
Ramesh 181.6K Reputation points Volunteer Moderator2026-07-12T05:31:01.81+00:00 From Page 34 of the MAG B660M MORTAR DDR4 manual.
https://download-2.msi.com/archive/mnu_exe/mb/MAGB660MMORTARWIFIDDR4_MAGB660MMORTARDDR4.pdf
Ramesh 181.6K Reputation points Volunteer Moderator2026-07-12T07:05:54.82+00:00 I was able to log in back to windows
Ok. Please follow the steps mentioned in this article.
Check if a device meets Windows 11 system requirements after changing device hardware | Microsoft Support: https://support.microsoft.com/en-us/windows/experience/compatibility/check-if-a-device-meets-windows-11-system-requirements-after-changing-device-hardware
Ramesh 181.6K Reputation points Volunteer Moderator2026-07-12T07:34:49.95+00:00 Pc health check says I can upgrade, I followed the instructions to manually refresh security and updates but it still says doesn't meet minimum requirements.
Yeah, thought so. That's why I suggested running that compatibility telemetry scheduled task.
Please share your Farbar scan logs for analysis.
- Download Farbar Recovery Scan Tool 64-bit FRST64.exe
- If the OS language is not English, rename
FRST64.exetoFRST64English.exe. - Run the program. Don't check or uncheck any options. Click "Scan".
- Add the two logs, FRST.txt and Addition.txt, to a zip archive.
- Share the zip file on OneDrive or GoFile.io, and post the link here.
Note: If Microsoft Edge or Chrome mislabels the Farbar Scanner executable as PUA/malware, choose to keep it by tapping … in the bottom bar, choosing Keep, and then choosing Keep anyway in the dialog that appears. See this screenshot. It's a safe tool used in most antimalware forums.
