Looping: what adblockers or extensions keep cloudfare looping?
Aziz Shalaby 0 Reputation points
2026-07-09T17:42:29.61+00:00
Cloudfare looping:
what adblockers and extensions keep the looping?
Microsoft Edge | Browser extensions | Windows 10
  1. Aziz Shalaby 0 Reputation points
    2026-07-10T16:57:23.61+00:00
    How do you disable all the browsers extensions and clear browsers caches and cookies?
  2. Bulldog 4,315 Reputation points
    2026-07-10T17:08:31.0766667+00:00
    How do you disable all the browsers extensions ...
    Browser extensions have to be individually disabled, unfortunately. Here are Microsoft's instructions to remove an extension from Microsoft Edge.
    ... and clear browsers caches and cookies?
    Here are Microsoft's instructions for how to clear browser cache and cookies.
  3. Thomas4-N 21,530 Reputation points Microsoft External Staff Moderator
    2026-07-18T09:59:06.3633333+00:00
    Hello Aziz Shalaby,
    There is no single ad blocker or extension that always causes this. Cloudflare notes that ad/content blockers, script blockers, fingerprinting protection, and VPN/proxy extensions can interfere with its verification process.
    I would try this:
    • Open the website in an Edge InPrivate window.
    • If it works there, open Extensions > Manage extensions, turn the extensions off, then re-enable them one at a time to identify the conflict.
    • If it still loops, delete the cookies for that specific website and restart Edge.
    • Also temporarily disconnect any VPN or proxy, update Edge, and try another network or device.
    This should help determine whether the loop comes from an extension, Edge’s stored site data, or the network rather than guessing a particular extension.
