How to disable Snap Layout on monitor?
Alan Ferguson 20 Reputation points
2026-07-09T12:51:33.9866667+00:00
I am unable to disable the Snap Layout function on my monitor. It is stuck in a three pane selection.
My setup is:
Dell XPS 14 - No snapping here
Dell S2722QC
Snap Windows is disabled in System>Multitasking
This is maddening, I hate the Snap layouts!
Windows for home | Windows 11 | Desktop, Start, and personalization | Desktop
DaveM121 933.8K Reputation points Independent Advisor
2026-07-09T13:27:38.1633333+00:00
If you have disabled Snap Layouts in the Windows Settings app, most likely this is caused by a Dell utility.
Open the Dell Display Manager app or Dell Display and Peripheral Manager app.
Navigate to the Easy Arrange settings and disable the 'Easy Arrange' setting.
If that was not the cause of the problem, please provide a screenshot of the grid that appears when you move a window on your screen.
0 additional answers
