Teams annotation and whiteboard in MTRs
Aitor Amozarrain 0 Reputation points
2026-07-09T12:48:57.5133333+00:00
I´m exploring Whiteboard an annotations for deployment of digital whiteboards (Touchscreens) for one of our clients.
Issues I´ve found:
*MTR on Android draws very sloppy and pencil tools do not respond (checked with different hardware, accounts and tenants with consistent result). On windows same usage works fine.
*Regarding the inability to start shared annotation or whiteboard from MTR itself, mayor issue arises with guests in the place, as they would usually connect to system via casting app/ dongle/ HDMI cable into the MTR itself. This disables all collaboration chances over their desktop (unless somebody captures and reshares what they are showing). Is there any way we could capture this local guest into the whiteboard at least?
Goal is to bring together 3 participants: Local host, Remote Guest (via Teams) and local Guest (with no access to teams but sitting right in the MTR room) and have them all share desktops and annotate and whiteboard together (while having audio and video feeds of course).
Any idea is higly appreciated.
Thanks for your time
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Screen sharing
  1. Liora D 18,920 Reputation points Microsoft External Staff Moderator
    2026-07-09T13:42:42.1733333+00:00
    Dear @Aitor Amozarrain,
    I hope you’re having a good day.
    Regarding your second question, based on the current Teams Rooms experience, I am not aware of a supported method to take a local HDMI/casting guest source and turn it into a collaborative Microsoft Whiteboard session that all participants can annotate directly. Microsoft Whiteboard collaboration is designed around meeting participants and shared whiteboards within Teams, rather than external HDMI input sources.
    For the scenario you described: Local Host (Teams Room) + Remote Guest (Teams) + Local Guest (HDMI / casting) the biggest limitation is that the local guest connected via HDMI or casting is essentially providing a video source to the room system and is not participating as a Teams or Whiteboard collaborator. As a result, annotation and Whiteboard features are not available to that person in the same way they are for Teams participants.
    Regarding the annotation experience on Teams Rooms on Android, Microsoft does support touch-enabled Whiteboard experiences on Android Teams Rooms devices, but since you have already tested multiple devices, accounts, and tenants and are consistently seeing poor pen behavior compared to Windows, I would be interested to know:
    • Which Teams Rooms on Android device models are being tested?
    • Which Teams Rooms app version is installed?
    • Are you experiencing this behavior in Microsoft Whiteboard specifically, or when annotating shared content?
    This would help determine whether you are encountering a device-specific issue or a limitation of the current Android implementation.
    Based on the collaboration scenario you are trying to achieve, my current understanding is that the most reliable approach would be for all contributors, including the local guest, to join the meeting as participants (even from a secondary device if appropriate). That allows everyone to interact with the same Whiteboard session directly rather than through an HDMI feed.
    Your use case is actually a very interesting one, and I believe it highlights a gap that other customers may also encounter when trying to combine in-room guests, remote attendees, Whiteboard collaboration, annotation, and content sharing into a single workflow.
    Looking forward to hearing back from you with any updates or additional details.
    Warm regards,
  2. kagiyama yutaka 5,330 Reputation points
    2026-07-10T14:18:45.82+00:00
    I think Teams Rooms on Windows and Android do not turn HDMI or casting input into anything Whiteboard or annotation can work on, and only people joining with a Teams client can use those tools. The easy way is just having the local guest join the same meeting from a phone or laptop and hit Share → Whiteboard, then all three write on the same board.
