Camera Not Working and Crackling Noise During Video Calls – Surface Pro 6 Hello Microsoft Support,
Abhishek Sharma 0 Reputation points
2026-07-09T07:48:08.4966667+00:00
Subject: Camera Not Working and Crackling Noise During Video Calls – Surface Pro 6
I am using a Microsoft Surface Pro 6, and I am experiencing a problem with the camera.
The Camera app does not open at all. Whenever I try to use the camera for video calls or video recording, it either fails to work or produces a continuous crackling/static noise.
I have already tried multiple troubleshooting steps, and I also had the device checked by a software engineer, but the issue is still not resolved.
Could you please help me identify the cause of this problem and advise me on the appropriate solution? If any hardware repair or further diagnostics are required, please let me know.
Thank you for your support. I look forward to your response.
Moved from Microsoft Teams | Microsoft Teams Free | Other
Surface | Surface Pro | Sound and camera
  1. Alex-L 12,555 Reputation points Microsoft External Staff Moderator
    2026-07-16T08:42:17.59+00:00
    Hi Abhishek Sharma
    A few additional details may help narrow this down further:
    • Does the camera appear under Device Manager > Cameras (or is it missing entirely)?
    • If you open the Camera app, do you receive a specific error code such as 0xA00F4244 or 0xA00F429F?
    • Does the crackling/static noise occur only during camera use, or is it also present when recording audio with the built-in microphone?
    • Have you tested whether the issue persists in a clean boot or in the UEFI environment?
    If the cameras are missing from Device Manager, remain undetected after the UEFI re-enable procedure, and the crackling noise continues, that would strengthen the case for a hardware fault involving the camera/microphone assembly or related internal connections. In that scenario, contacting Surface Support to discuss repair or replacement options would likely be the next step. Microsoft also recommends updating Surface drivers/firmware and using the Surface Diagnostic Toolkit as part of the support process.
    Note: Please follow the steps outlined in our documentation to enable email notifications if you wish to receive notifications regarding this discussion.
  2. Deleted
  3. Amir Ashraff 0 Reputation points
    2026-07-09T07:54:44.22+00:00
    Hi Abhishek,
    This is a frustrating issue, especially since a software engineer has already looked at it. The combination of the camera app failing to open and a continuous crackling/static noise during video attempts strongly suggests either a severe hardware conflict or a physical failure in the camera/microphone module assembly (as they often share the same flex cable and internal grounding paths).
    Before declaring it a hardware failure, here are the definitive steps to isolate and hopefully resolve the issue:
    1. Force a Hardware-Level Reset
    Sometimes standard restarts don't clear stuck firmware in the camera module.
    Shut down your Surface Pro 6 completely.
    Press and hold the Volume Up button and the Power button at the same time for at least 15 seconds, then release both. (The Surface logo may flash, but keep holding for the full 15 seconds).
    Wait a few seconds, then turn it back on normally and test the camera.
    2. Check the Surface UEFI Settings
    We need to ensure the hardware isn't disabled at the motherboard level.
    Shut down your device.
    Press and hold the Volume Up button, then press and release the Power button.
    Release the Volume Up button when the Surface logo appears; you will enter the UEFI menu.
    Go to Devices and look for Front Camera, Rear Camera, and IR Camera.
    If they are toggled On, toggle them Off, save and exit, and let Windows boot up.
    Then, restart back into UEFI and toggle them back On. This forces Windows to completely re-detect the hardware.
    3. Reinstall the Intel Control Logic Driver
    The crackling sound combined with a camera failure usually points to the audio/video interface driver.
    Right-click the Start menu and select Device Manager.
    Expand the System devices section.
    Look for Intel(R) Control Logic (there might be more than one).
    Right-click it and select Uninstall device. If prompted, do not check the box to delete the driver software.
    Restart your Surface. Windows will automatically reinstall the driver.
    4. Run the Official Surface Diagnostic Toolkit
    Microsoft provides a dedicated tool that checks for specific hardware-firmware mismatches on Surface devices.
    • Download and run the Surface Diagnostic Toolkit from the official Microsoft support page. It will run an automated suite of tests specifically tailored to your hardware.Hi Abhishek, This is a frustrating issue, especially since a software engineer has already looked at it. The combination of the camera app failing to open and a continuous crackling/static noise during video attempts strongly suggests either a severe hardware conflict or a physical failure in the camera/microphone module assembly (as they often share the same flex cable and internal grounding paths). Before declaring it a hardware failure, here are the definitive steps to isolate and hopefully resolve the issue:
      • Shut down your Surface Pro 6 completely.
      • Press and hold the Volume Up button and the Power button at the same time for at least 15 seconds, then release both. (The Surface logo may flash, but keep holding for the full 15 seconds).
      • Wait a few seconds, then turn it back on normally and test the camera.
      • Shut down your device.
      • Press and hold the Volume Up button, then press and release the Power button.
      • Release the Volume Up button when the Surface logo appears; you will enter the UEFI menu.
      • Go to Devices and look for Front Camera, Rear Camera, and IR Camera.
      • If they are toggled On, toggle them Off, save and exit, and let Windows boot up.
      • Then, restart back into UEFI and toggle them back On. This forces Windows to completely re-detect the hardware.
      • Right-click the Start menu and select Device Manager.
      • Expand the System devices section.
      • Look for Intel(R) Control Logic (there might be more than one).
      • Right-click it and select Uninstall device. If prompted, do not check the box to delete the driver software.
      • Restart your Surface. Windows will automatically reinstall the driver.
