Building custom solutions that extend, automate, and integrate Microsoft 365 apps.
Based on the detailed configuration you shared, I understand that you are trying to pass a dynamic contextual variable (selectedIndustry) from a Power Apps canvas app dropdown into an embedded Copilot Studio agent. While you have correctly configured the agent's global variable to accept external values ("External sources can set values" turned ON) and removed any conflicting logic in ConversationStart, appending the variable as a query string parameter to the Chatbot control's Endpoint property is not causing the agent to pick up the value.
Here is the technical breakdown of why this approach is failing and the recommended steps to implement a supported, future-proof solution.
-I have not found Microsoft documentation indicating that appending query-string parameters to the Chatbot control Endpoint property is a supported mechanism for setting Copilot Studio global variables. While appending query strings directly to an embed URL works for standard custom website deployments, the native Power Apps Chatbot control acts as a restrictive wrapper around Web Chat. It handles authentication and endpoint routing internally, and it does not parse, forward, or expose URL query parameters into Copilot Studio global variables.
-For traditional custom web environments, Microsoft officially documents two ways to initialize external global variables:
- Query Strings (For standard iframe embeds): You can append the parameter directly to the default agent web-chat URL schema: https://web.powerva.microsoft.com/webchat/bots/<botId>?selectedIndustry=Consumer%20Market
- Backchannel Events (For Custom React Web Chat): For custom deployments, Microsoft recommends injecting a custom event (pvaSetContext) into the Web Chat Redux store upon connection:
const store = WebChat.createStore(
({ dispatch }) =>
next =>
action => {
if (action.type === "DIRECT_LINE/CONNECT_FULFILLED") {
dispatch({
type: "WEB_CHAT/SEND_EVENT",
payload: {
value: {
selectedIndustry: "Consumer Market"
return next(action);
However, within a Canvas App utilizing the default Chatbot Control, you do not have access to JavaScript APIs, Web Chat middleware, or the underlying store to dispatch events directly. Therefore, you cannot natively pass variables at conversation start or update them mid-session using the built-in control.
-In a Power Apps canvas app, the built-in Chatbot control does not appear to expose the WebChat middleware/event layer needed to dynamically send context variables when a dropdown changes. Therefore, changing the dropdown mid-session is not something I would expect to work through the Endpoint property alone. The safer approach is either to restart the chat session with the new context, or move to a custom WebChat/PCF-based component where the canvas app can send a custom event to the Copilot Studio agent.
Also note that the Copilot/Copilot answer controls for canvas apps are being deprecated for new apps starting February 2, 2026. Microsoft recommends Microsoft 365 Copilot in canvas apps for natural-language app experiences. However, if the requirement is specifically to embed an existing Copilot Studio agent and pass custom app context into it, a PCF/WebChat implementation is currently the more suitable approach because it can send startup or runtime events into the agent
Please refer the following document: Add a Copilot control to a canvas app (preview)
I hope this information help.
