GMX und Outlook
Matthias Schmidt 20 Reputation points
2026-07-06T09:00:27.41+00:00
Ich kann mein GMX Konto nicht mehr mit Outlook abrufen.
Ichs sehe das Konto noch in Outlook, kann es aber nicht löschen und neu installieren.
SD - IA 179.8K Reputation points Independent Advisor
2026-07-06T09:55:21.2933333+00:00
I can understand the frustration caused by the issue. Please remove the mail profile and check:
  • Close Outlook completely.
  • Open Control Panel and change View by to Large icons or Small icons.
  • Select Mail (Microsoft Outlook).
  • Click Show Profiles.
  • Select the Outlook profile you want to remove.
  • Click Remove, then confirm the deletion.
  • Click OK to save the changes.
I’m eager to hear back and work together to find a solution.
0 additional answers
