How to fix lenovo yoga 11e when it restarts whenever I open my camera
JOSHUA ODONGO 0 Reputation points
2026-07-06T04:59:12.5533333+00:00
My lenovo yoga 11e laptop keeps on restarting whenever I open my camera. what could be the issue??
Windows for home | Windows 10 | Windows ink and touch
  1. Thileep Kumar 4,220 Reputation points Independent Advisor
    2026-07-06T05:48:01.38+00:00
    Hi, when did the issue start? Was it working fine before? Does this happen only when opening the Camera app?
    Have you tried try reinstalling the Camera app? Go to Settings > Apps > Installed apps. Find Camera, click the three dots, and select Uninstall. Restart your PC, then reinstall the Camera app from the Microsoft Store
    Also, please try updating the camera driver: Go to Device Manager > Cameras, right-click your camera, and select Update driver. If that doesn’t help, uninstall it and restart your laptop.
    Additionally, Could you please share the system logs?
    Press Windows key + X and select Event Viewer
    Expand Windows Logs
    Right-click System > select Filter Current Log
    Check Critical, Warning, and Error, then click OK
    On the right pane, click Save Filtered Log File As...
    Save the file to your desktop
    You can then share the file using OneDrive using this guide: https://support.microsoft.com/en-us/office/share-onedrive-files-and-folders-9fcc2f7d-de0c-4cec-93b0-a82024800c07
    Once shared, I’ll review the logs and help you further.
