How to fix: A configuration issue prevents CDN from working: The "Account name", "Account key" and "Container" fields cannot be empty.
Phil Huhn 0 Reputation points
2026-07-05T20:50:24.6066667+00:00
I'm running WordPress under Azure. Within WordPress on the Pluggins panel I'm getting an error alert stating the follows:
WordPress does have a link stating, "Specify it here." but it doesn't work and states, "Sorry, you are not allowed to access this page.". How do I configure account name, key and container?
Another side effect is I can't upload new images/media.
Azure Content Delivery Network
  1. Phil Huhn 0 Reputation points
    2026-07-06T17:02:48.6066667+00:00
    Thanks a lot. I didn't know that the CDN is configured via the W3 Total Cache plugin.
    When I go to that part in W3 Total Cache plugin, it has an Account Name and a Container Name that is identical to the Account Name but it has "blob" in front of it. The Account Key is blank. In Azure I found the blob storage Account Name that matches the Account Name in WordPress. This blob storage configuration has an Account Key and a Connection String. I'm assuming I do the following
    1. copy the Azure Account Key into W3 Total Cache setting,
    2. click create container,
    3. click Save Settings,
    4. click the "Test Microsoft Azure Storage upload" button.
