How to refresh recycle bin after calling [IFileOperation.DeleteItem] or [SHFileOperation]
iamoon-6427 85 Reputation points
2026-07-04T22:47:13.9133333+00:00
INFO
  • OS Windows 11 profession, 25H2, 26200.8655
  • Visual Studio latest with latest Windows SDK, etc
DETAILS
  • I have tried to implement a cmd line tool to move specific items to recycle bin on Windows.
After successfully calling IFileOperation -> DeleteItem or the old one SHFileOperation, it did perform the remove action.
However, the recycle bin on my desktop still show an empty icon, it did not refresh its state only until I open it in the file explorer (double click the icon on desktop).
When it's not refreshed yet, right click on it, showing the menu, option empty recycle bin is not clickable, same until manually open it.
I have tried:
  • reboot my PC
  • call SHChangeNotify(SHCNE_UPDATEITEM...) or SHChangeNotify(SHCNE_ALLEVENTS)
  • check
But none of them work.
I doubt whether I miss something here, but cannot find the resolution...
If needed, I can provide my code here or on github, but the logic is basically the same as the HRESULT DeleteSampleFiles(IShellItem *psiSrc, IShellItem *psiDst) of Microsoft github example, except that add below code:
HRESULT DeleteSampleFiles(IShellItem* psiSrc, IShellItem* psiDst)
    IFileOperation* pfo;
    HRESULT hr = CreateAndInitializeFileOperation(IID_PPV_ARGS(&pfo));
    if (SUCCEEDED(hr))
        // below line is what I add, let delete folders stay in recycle bin
        // instead of delete permanently
        hr = pfo->SetOperationFlags(FOFX_RECYCLEONDELETE);
        if (SUCCEEDED(hr))
            hr = pfo->DeleteItem(psiSrc, NULL);
            if (SUCCEEDED(hr))
                hr = pfo->DeleteItem(psiDst, NULL);
                if (SUCCEEDED(hr))
                    hr = pfo->PerformOperations();
        pfo->Release();
    return hr;
Thanks a lot if someone can help!
Windows development | Windows API - Win32
RLWA32 52,916 Reputation points
2026-07-05T07:17:24.17+00:00
I reproduced your observations on Win10 22H2. The following caused the desktop icon of the Recycle bin to refresh after an item was recycled from a console application. For example purposes all error checking is omitted.
int wmain(int argc, wchar_t *argv[])
    auto hr = CoInitialize(nullptr);
        CComPtr<IShellItem> psibin, psifile;
        CComPtr<IFileOperation> pfo;
        CComPtr<IShellView> psv;
        // Fully qualified path of file to be recycled
        hr = SHCreateItemFromParsingName(argv[1], nullptr, IID_PPV_ARGS(&psifile));
        hr = SHGetKnownFolderItem(FOLDERID_RecycleBinFolder, KF_FLAG_DEFAULT, NULL, IID_PPV_ARGS(&psibin));
        hr = psibin->BindToHandler(nullptr, BHID_SFViewObject, IID_PPV_ARGS(&psv));
        hr = pfo.CoCreateInstance(CLSID_FileOperation, nullptr, CLSCTX_INPROC_SERVER);
        hr = pfo->DeleteItem(psifile, nullptr);
        hr = psv->Refresh();
    CoUninitialize();
    return 0;
I wasn't able to test this code on Win 11.
Taki Ly (WICLOUD CORPORATION) 5,300 Reputation points Microsoft External Staff Moderator
2026-07-06T04:01:51+00:00
Hello @iamoon-6427 ,
After looking into this further, I would point you to RLWA32's answer, which appears to be the reliable approach. I tested this on Windows 11 25H2. Binding to the Recycle Bin's view object and calling IShellView::Refresh() after PerformOperations() did update the desktop icon from empty to full, exactly as RLWA32 described for Win10 22H2:
CComPtr<IShellItem> psibin;
// ... after pfo->PerformOperations() ...
psv->Refresh();   // this is what updates the desktop icon
For completeness, on the same 25H2 machine I tested SHUpdateRecycleBinIcon and SHChangeNotify with SHCNE_UPDATEIMAGE, SHCNE_UPDATEITEM, and SHCNE_ASSOCCHANGED in isolation, and none of them updated the icon, only the IShellView::Refresh() call did. That is consistent with what you reported, since SHCNE_UPDATEITEM was already among the things you had tried.
Hope the information helps! If you found my response helpful or informative, I would really appreciate it if you could follow this instruction for your confirmation.
Thank you.
1 additional answer
  1. iamoon-6427 85 Reputation points
    2026-07-06T19:07:25.9366667+00:00
    Thanks everyone! It's a bit strange that windows document not mentioning how to refresh the icon. The reason why I try SHChangeNotify is that source code of deletefiles in dotnet shows that we should call this after shell operations:
    NativeMethods.SHChangeNotify(
    SHChangeEventTypes.SHCNE_DISKEVENTS,SHChangeEventParameterFlags.SHCNF_DWORD, IntPtr.Zero, IntPtr.Zero
    Not seeing any other section related to icon refresh...
    I try to reimplemnet it in C++, to test if it's useful (don't want to install dotnet just for a test). But just like I said before, this does not work.
