how to input data from a spreadsheet into a macro
David Hill 100 Reputation points
2026-07-03T15:30:56.5633333+00:00
What's the simplest way to pass a number (such as a month number) in a cell of my EXCEL spreadsheet into a macro? I have Excel 24, not 365.
Developer technologies | Visual Basic for Applications
Tom Tran (WICLOUD CORPORATION) 5,945 Reputation points Microsoft External Staff Moderator
2026-07-06T03:51:23.34+00:00
Hi @David Hill ,
You can read the cell value directly in VBA.
If the month number is always in a fixed cell, for example A1 on Sheet1, use:
Sub TestMacro()
    Dim monthNumber As Long
    monthNumber = ThisWorkbook.Worksheets("Sheet1").Range("A1").Value
    MsgBox "Month number is " & monthNumber
End Sub
Change "Sheet1" and "A1" to match your actual sheet and cell.
If you want the macro to use the currently selected cell instead, use:
Sub TestMacro()
    monthNumber = ActiveCell.Value
End Sub
For a simple month number, .Value is enough. This works in Excel 2024 as well; it does not require Microsoft 365.
You can check these Microsoft VBA references for more information: Range.Value property and Working with the active cell.
If you found my response helpful or informative, I would greatly appreciate it if you could follow this guidance. Thank you.
John Jefferson Doyon 88,240 Reputation points Independent Advisor
2026-07-03T16:08:32.3333333+00:00
Hi, I'm John! I will help you with this.
The simplest way is to read the cell value directly in the VBA macro.
For example, if the month number is in cell A1:
Sub TestMacro()
    Dim monthNumber As Integer
End Sub
Just replace Sheet1 and A1 with the actual sheet name and cell you are using.
Excel 2024 can still use VBA macros, so this should work as long as macros are enabled.
Can you confirm where the number is entered? For example, is it in a fixed cell like A1, or do you want the macro to use the currently selected cell?
Senthil kumar 2,500 Reputation points
2026-07-03T15:50:11.3166667+00:00
Hi @David Hill
Sub Test()
    Dim v As Variant
    v = Range("G7").Value   'Reads cell G7
    MsgBox v
End Sub
Thanks.
0 additional answers
