Azure Files Premium (NFSv4.1) — "Remote I/O error" from both Azure and on-prem clients
Shing Fan LEE 20 Reputation points
2026-07-01T20:29:23.9333333+00:00
Environment
  • Azure Files Premium file share, NFSv4.1 protocol
  • Storage account: [redacted — will provide privately]
  • Region: [your region]
  • Clients: Linux VMs inside Azure (same region) and on-premises Linux clients reaching the share over private connectivity
  • Access via private endpoint on the storage account
Problem Mounts succeed, but I/O intermittently fails with Remote I/O error (EREMOTEIO). It affects both Azure-internal clients and on-prem clients, which suggests the issue is at the share/storage layer rather than a single client's network path.
What I've already checked
  • secure transfer required / protocol settings confirmed for NFS
  • Private endpoint DNS resolves to the private IP from both Azure and on-prem
  • No NoRootSquash/permission mismatch — failures happen mid-I/O, not at mount
  • Reviewed storage metrics for throttling (Transactions, Success E2E Latency, Availability) around the failure timestamps
  • Confirmed the share hasn't hit provisioned IOPS/throughput limits at the failure times *(adjust if not true)*Environment
    Problem
    Mounts succeed, but I/O intermittently fails with Remote I/O error (EREMOTEIO). It affects both Azure-internal clients and on-prem clients, which suggests the issue is at the share/storage layer rather than a single client's network path. What I've already checked
    • Confirmed the share hasn't hit provisioned IOPS/throughput limits at the failure times (adjust if not true)
Azure Files
Azure Files
An Azure service that offers file shares in the cloud.
  1. Christos Panagiotidis 3,551 Reputation points
    2026-07-19T10:52:39.8133333+00:00
    EREMOTEIO is the Linux client's surfaced error, so it does not by itself prove the share is failing. In Azure Monitor, use the exact UTC failure window and compare SuccessServerLatency with SuccessE2ELatency. Low server latency but high end-to-end latency points to the client or network; elevated server latency or availability failures point toward the service. Also filter Transactions by Response type for premium-share throttling, including ClientShareIopsThrottlingError and the ingress/egress equivalents; totals can hide short bursts.
    Reproduce from one same-region VM using a supported, current Linux kernel and documented NFS 4.1 mount settings. Capture dmesg/journalctl output, mount options, the affected path and operation, and exact UTC timestamps. If the same operation fails there while throttling is absent and server latency or availability degrades, open an Azure support request with the timestamps and storage account/share identifiers so Microsoft can trace the backend requests.
