Peering configuration traffic flow
VishalKulkarni-0961 0 Reputation points
2026-07-01T17:56:39.8466667+00:00
We have Azure Domain Controllers in AllianceVMXSupernet that successfully communicate with our on-premises Domain Controllers. Based on our peering configuration, we cannot determine how this traffic is routed.
Kindly guide regarding the steps to identify the traffic flow
Azure VPN Gateway
Azure VPN Gateway
An Azure service that enables the connection of on-premises networks to Azure through site-to-site virtual private networks.
    2026-07-01T17:57:06.84+00:00
    Use Azure’s network diagnostic tools to trace how traffic between AllianceVMXSupernet and on-premises domain controllers is routed.
    1. Verify effective routes on the NICs
      • For a VM in AllianceVMXSupernet, open its network interface in the Azure portal.
      • View Effective routes to see:
        • System routes for virtual network peering.
        • Routes learned from VPN/ExpressRoute (BGP).
        • Any user-defined routes (UDRs).
      • This shows whether traffic to the on-premises DC prefixes is using:
        • The VPN/ExpressRoute gateway as next hop, or
        • A peered VNet (hub) and then a gateway (gateway transit), or
        • An NVA.
    2. Check for peering and gateway transit
      • For the VNet containing AllianceVMXSupernet, check Peering settings:
        • Confirm if Use remote gateways is enabled.
      • On the hub VNet (if using hub-and-spoke), check if:
        • A VPN/ExpressRoute gateway exists.
        • Allow gateway transit is enabled on the peering.
      • In such designs, traffic between peered VNets and on-premises flows over the Azure backbone via the peering, using the hub gateway as transit.
    3. Use Network Watcher “Next hop”
      • Enable Network Watcher in the region.
      • Use Next hop from a VM in AllianceVMXSupernet to an on-premises DC IP.
      • The result will show the actual next hop type:
        • VirtualNetworkGateway (VPN/ExpressRoute gateway),
        • VirtualNetworkPeering (traffic first goes to a peered VNet), or
        • VirtualAppliance (NVA).
      • This confirms whether the traffic is going directly via the gateway, via a hub VNet, or via an NVA.
    4. Check for route conflicts/overrides
      • If an NVA or custom routing is used, review any route tables associated with AllianceVMXSupernet subnets:
        • Ensure no UDR is unintentionally overriding the expected gateway/peering route.
      • If BGP is used from on-premises, verify that advertised prefixes do not overlap with peered VNet address spaces in a way that confuses diagnostics; confirm peering system routes take precedence.
    5. Confirm on-premises path
      • On the on-premises side, inspect the VPN/ExpressRoute configuration and routing to see which Azure VNet prefixes are advertised and how return traffic is sent.
    These steps together (Effective routes + Next hop + peering/gateway settings) will show the exact path that domain controller traffic takes between AllianceVMXSupernet and on-premises.
