Post removed immediately after creating, no specific reason given.
Andrew Holland 40 Reputation points
2026-07-01T14:56:52.4466667+00:00
Hello, my question on an Azure Automation bug was removed:
Link: https://learn.microsoft.com/en-us/answersazure-automation-source-control-is-consistently-fa
Message:
Is it possible for this to be restored so I can get help with the issue?
Community Center | Discuss the Q&A site | Site bug or problem
Erland Sommarskog 137.5K Reputation points MVP Volunteer Moderator
2026-07-01T15:20:40.8233333+00:00
I have undeleted your post. The spam filter on this site can be quite aggressive at times - but so can the spammers, which may explain that the deletion bar is a tad low.
However, I have a piece of advice: You had some fairly long pieces of log output in your post. I may be better to put such output in files that you attach. You should certainly do this if the files are longer. At least that is my preference when I answer questions in my area of expertise (which is a different one from your question). To much log files etc makes it difficult to follow the discussion in the thread.
0 additional answers
