How do i fix these threats that has been going on for days, when i clicked the take action button it's taking so long to complete it, is this normal?
Aich Reinhardt 20 Reputation points
2026-06-29T17:25:59.74+00:00
Screenshot 2026-06-30 002319
David-M 126.5K Reputation points Independent Advisor
2026-06-29T18:05:21.73+00:00
Hi. I'm David, and I'm happy to help you.
This infinite loading loop is a classic Windows Defender bug. It happens because the threat has likely already been removed, so the system gets confused trying to take action on a file that doesn't exist anymore.
Let's double-check your PC for safety and then force Windows to clear these stuck alerts. Here is what you need to do:
To ensure that your computer has no threats, I suggest you perform a full scan using Microsoft Safety Scanner. Download from the link below.
https://docs.microsoft.com/en-us/windows/security/threat-protection/intelligence/safety-scanner-download
Also, perform a full scan using Malwarebytes as a second opinion.
Download through this link: https://malwarebytes.com/
After scanning, you can uninstall it.
If both tools do not report threats and the threat notification keeps showing, do the following:
  1. Open File Explorer, paste the address below into the address bar, and press Enter:
C:\ProgramData\Microsoft\Windows Defender\Scans\History\Service\
(If you are unable to access this directory, see the Note below.)
  1. Inside this folder, delete the folder "DetectionHistory";
  2. Then restart your computer.
Then, see if the notification is no longer showing and run a scan now using Defender, just in case.
If you are unable to access the mentioned folder due to a permissions error, start Windows in Safe Mode and try again.
https://support.microsoft.com/en-us/windows/start-your-pc-in-safe-mode-in-windows-92c27cff-db89-8644-1ce4-b3e5e56fe234#WindowsVersion=Windows_11
Feel free to ask any questions you may have.
Standard Disclaimer: There is a link to a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
0 additional answers
