How to clean up V drive on Window 11
wadesmith 40 Reputation points
2026-06-29T06:50:10.6966667+00:00
My C drive shows that installed apps take up 68.3gb of storage. But when I come to see what apps are they, there are only a few apps that take up about 5gb in C drive. Is there anything I can do to know what is eating up my C drive?
Bosch, Bert 80 Reputation points
2026-06-29T07:28:44.92+00:00
Windows often reports “Installed apps” much higher than the visible app list because that category can include hidden app data, Microsoft Store apps, old installers, shared runtimes, game launchers, and app folders that do not show clearly in Settings.
Here’s how to find what is eating your C drive.
  1. Check hidden app data
A lot of “app storage” is actually here:
C:\Users<your name>\AppData\Local
C:\Users<your name>\AppData\Roaming
To see it:
Open File Explorer.
Go to your user folder.
Click View > Show > Hidden items.
Open AppData.
Look for large folders.
Common space users include:
AppData\Local\Temp
AppData\Local\Packages
AppData\Local\Google
AppData\Local\Microsoft
AppData\Roaming\Adobe
AppData\Roaming\Microsoft
  1. Run Windows cleanup tools
Go to:
Settings > System > Storage
Then open:
Temporary files
You can usually safely remove:
Temporary files
Recycle Bin
Windows Update Cleanup
Delivery Optimization Files
Thumbnails
DirectX Shader Cache
Be careful with:
Downloads
Only select Downloads if you really want to delete those files.
Also run:
Disk Cleanup
Then choose:
Clean up system files
  1. Check for old Windows update files
Windows updates can take many GB.
Open Command Prompt as Administrator and run:
DISM /Online /Cleanup-Image /StartComponentCleanup
This can reduce the size of the Windows component store.
  1. Check hibernation file
Windows may reserve several GB for hibernation.
To disable hibernation, open Command Prompt as Administrator and run:
powercfg -h off
This removes:
C:\hiberfil.sys
Do this only if you do not use Hibernate or Fast Startup.
  1. Check system restore points
System Restore can use a lot of space.
Go to:
Control Panel > System > System Protection
Select C drive, click Configure, and check Disk Space Usage.
You can reduce the maximum usage or delete old restore points.
  1. Use PowerShell to find largest folders
Open PowerShell as Administrator and run this:
Get-ChildItem C:\ -Force -Directory -ErrorAction SilentlyContinue |
ForEach-Object {
$size = (Get-ChildItem $_.FullName -Recurse -Force -ErrorAction SilentlyContinue |
    Measure-Object Length -Sum).Sum
[PSCustomObject]@{
    Folder = $_.FullName
    SizeGB = "{0:N2}" -f ($size / 1GB)
} | Sort-Object {[double]$_.SizeGB} -Descending | Select-Object -First 20
This may take a while, but it will show the largest top-level folders.
DaveM121 933.9K Reputation points Independent Advisor
2026-06-29T07:25:26.7966667+00:00
File Explorer is not very good at showing where the space on your drive is being used, because it does not show the size of folders and there are many hidden files and folders on the C drive.
Download the free TreeSize app from the Microsoft Store.
Very Important - to run TreeSize, you must right click its icon and choose Run as Administrator.
Please provide a screenshot of your C drive in that TreeSize utility, so I can see your hard drive and work out where that space is being used and if there is an underlying problem.
Please ensure the full TreeSize window is in the screenshot, there is information on the top and bottom bars I needs to see.
0 additional answers
