accounts requiring secondary verification
Fair Deal 0 Reputation points
2026-06-27T22:42:10.1633333+00:00
Upon signing in to any microsoft account, I am asked for secondary login. Particularly accounts I use less frequently, but still need access to. I used to use a temporary cell phone code. Now, using an alternate email address if forced to. Usually now, the alternate email address also asks for a secondary login verification. Then the third. Etcetera, until I have used all my back up methods which all now require another method. I have done all verification processes and have had a microsoft account for most of my life. Never has it been like this. This is currently causing issues with everything related to my email accounts every single time I try and use it for something. Every secondary verification method requiring a secondary method, until, ultimately, I am out of methods and have to create a new email address which will eventually also require a secondary method and lock me out when I need it to just work. In the past 2 months, this experience has really gotten terrible. I'm signing into an email. Something I have done seamlessly for the past 25 years. It would seem as though email accounts are more necessary than ever before, and harder to use than ever before. I am tired of being locked out of my account by way of secondary verification all the time. How is it possibly more secure to send sensitive data and temporary codes to verify accounts than to just verify by the password that I set up and is only in my mind? This is ruining the experience for the actual users. How can this be remedied or fixed so that my email accounts are usable again when I intend to use them?
Microsoft Security | Microsoft Identity Manager
    2026-06-27T22:42:34.0233333+00:00
    Microsoft accounts are increasingly enforcing secondary verification (security info and two-step verification) to protect against account takeover, especially on accounts that are used infrequently or show unusual activity. That is why sign-in now often requires more than just the password.
    There are a few things that can be done to reduce the “verification loop” and make the accounts usable again:
    1. Review and update security info in one place
      For personal Microsoft accounts:
      • Go to the Security basics page and sign in: https://account.microsoft.com/security
      • Select Update info or Advanced security options > Get started.
      • Make sure there is at least one method that is reliable and always accessible (for example, a current mobile number or an email that does not itself require extra verification to access).
      • Add new security contact info if needed (email, phone, or app), then enter the security code sent to that method so it becomes active.
    2. Avoid using one Microsoft account to verify another
      If the alternate email ends in @outlook.com, @hotmail.com, @live.com, or @msn.com, then one Microsoft account is being used to verify another. When signing into the second account to get the code, the browser may sign out of the first account, which can cause repeated prompts and confusion.
      To get verification codes reliably in that scenario:
      • Open a browser in privacy/InPrivate mode.
      • Sign in with the first account and keep that window open when it asks for a code.
      • Open a second privacy/InPrivate window, sign in to the alternate email account, and retrieve the code.
      • Return to the first window and enter the code.
    3. Replace outdated or unusable security info
      If a phone number or email is no longer accessible, or every method now triggers another verification step:
      • On the “Verify your identity” screen, choose “I don’t have any of these” and follow the prompts to replace the security information.
      • Be aware: if all previous security info is removed and replaced, the account may be put into a restricted state for 30 days, during which changes are limited.
    4. Reduce how often codes are required (trusted devices)
      On devices that are used regularly:
      • Go to the Security settings page and sign in.
      • When prompted for a security code, enter it.
      • Select “I sign in frequently on this device. Don’t ask me for a code.” and submit.
        This marks the device as trusted, so security codes are not requested every time sensitive info is accessed.
    5. If verification methods are blocked or looping
      • If seeing messages like “Try another verification method”, it may be due to unusual activity, high volume of requests, or temporary blocks.
      • Try a different verification method (e.g., alternate email instead of SMS), or a different network (switch Wi‑Fi/cellular).
      • Avoid repeated attempts; waiting 24 hours up to a week can allow blocks to clear.
      • Use the sign-in helper tool for guided troubleshooting: https://go.microsoft.com/fwlink/?linkid=2241206.
    6. If still unable to sign in or receive codes
      • Use the sign-in helper: https://go.microsoft.com/fwlink/?linkid=2300860.
      • For technical support (not for codes or password resets), go to Contact Microsoft Support and select Get Help, then Contact Support if needed. Support cannot send verification codes or change account details but can help diagnose sign-in issues.
    These steps focus on ensuring there is at least one stable, accessible verification method, avoiding account-to-account verification loops, and marking frequently used devices as trusted so that secondary verification is not required every time.
