Posershell script to install *.cab and *.msu
Boopathi S 4,036 Reputation points
2026-06-27T15:40:35.91+00:00
Hello Team,
Share the powershell script to install the below files in remote computeres
SSU-26100.8648-x64.cab
windows11.0-kb5094126-x64.msu
Windows for business | Windows Server | User experience | PowerShell
Marcin Policht 109.4K Reputation points MVP Volunteer Moderator
2026-06-27T16:40:47.39+00:00
# List of remote computers
$Computers = @(
    "PC01",
    "PC02",
    "PC03"
# Source files location
$SourcePath = "\\FileServer\Updates"
# Update files
$SSUFile = "SSU-26100.8648-x64.cab"
$MSUFile = "windows11.0-kb5094126-x64.msu"
# Remote temp folder
$RemoteTemp = "C$\Temp\Updates"
foreach ($Computer in $Computers) {
    Write-Host "Processing $Computer ..." -ForegroundColor Cyan
    # Create remote folder
    Invoke-Command -ComputerName $Computer -ScriptBlock {
        New-Item -Path "C:\Temp\Updates" -ItemType Directory -Force | Out-Null
    # Copy files
    Copy-Item "$SourcePath\$SSUFile" "\\$Computer\$RemoteTemp\" -Force
    Copy-Item "$SourcePath\$MSUFile" "\\$Computer\$RemoteTemp\" -Force
    # Install updates remotely
        $SSU = "C:\Temp\Updates\SSU-26100.8648-x64.cab"
        $MSU = "C:\Temp\Updates\windows11.0-kb5094126-x64.msu"
        Write-Host "Installing SSU..."
        dism /Online /Add-Package /PackagePath:$SSU /Quiet /NoRestart
        Write-Host "Installing MSU..."
        wusa.exe $MSU /quiet /norestart
    Write-Host "$Computer completed." -ForegroundColor Green
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
0 additional answers
