microsoft edge
Alan Green 0 Reputation points
2026-06-27T09:49:44.48+00:00
microsoft edge is too slow to respond to website requests
Microsoft Edge | Speed and responsiveness | Windows 11
  1. Estrella721 45,815 Reputation points Independent Advisor
    2026-06-27T10:32:01.66+00:00
    To determine whether the issue is specific to Microsoft Edge, please try accessing the same website using another browser, such as Google Chrome or Mozilla Firefox. Does the website also respond slowly there?
    Also, are you connected to a stable internet connection?
    First, try restarting your computer and then check if the issue persists.
    If you're using a VPN or antivirus program, try temporarily disabling or uninstalling it to see if the problem goes away.
    If the issue continues, try clearing the Edge cache and cookies. Open Edge, click the three dots, then go to Settings > Privacy, search, and services > Clear browsing data > Choose what to clear. Select Cookies and other site data and Cached images and files, but do not select Passwords, then click Clear now.
    If the issue still persists, reset Edge by going to Settings > Reset settings > Restore settings to their default values > Reset. This will not delete your saved passwords, favorites, or browsing history. Restart your computer and check if the issue is resolved.
