How to add a link to a SharePoint for an excel file that will open directly in Excel Desktop not Browser
Cornes, Kaitlyn 20 Reputation points
2026-06-26T16:07:34.72+00:00
Hi -
I have a company Sharepoint page that is shared with a large audience. On one page of SharePoint we link to an excel file but it opens in the browser version of excel and not the desktop version. We would like the link to open in the desk top version. I saw a previous Q&A where someone asked a similar question and they were told to modify the link using this format:
ms-excel:ofv|u|https://[yourtenant].sharepoint.com/sites/[sitename]/[path]/filename.xlsx
However, on SharePoint the link must start with https:// in order to be added. Is there a way to modify the link to the excel file to open in excel desktop instead of browser?
Microsoft 365 and Office | SharePoint | For business | Other
2026-06-26T17:58:48.65+00:00
Hi Cornes
Thank you for reaching out and for sharing your concern.
Microsoft's Office URI Schemes documentation confirms that the ms-excel:ofv|u| URI can be used to launch the locally installed Excel desktop application and open a workbook from an HTTPS URL. Therefore, if you can edit the target URL, you can prepend the Excel URI scheme to your SharePoint file link using the following format:  ms-excel:ofv|u|https://yourtenant.sharepoint.com/sites/site/Shared%20Documents/filename.xlsx  When users select this link on a device where Microsoft Excel is installed and registered as the handler for the ms-excel protocol, the workbook should open in the Excel desktop application rather than Excel for the web.
Based on the format you referenced from the previous Q&A discussion, modifying the URL by adding ms-excel:ofv|u| before the SharePoint HTTPS address is the supported Office URI Scheme approach for opening the workbook in the Excel desktop application.
If you need a more sustainable solution for a document library that is accessed by a large audience, you may also consider configuring the library to open Office documents in the desktop app by default.
To do this, please reach out to your SharePoint site admin and share these steps:
  1. Open the SharePoint document library that contains the Excel file.
  2. Select Settings (gear icon) > Library settings.
  1. Select More library settings.
  1. Select Advanced settings.
  1. Locate Opening Documents in the Browser.
  2. Change the setting from Open in the browser to Open in the client application.
  1. Select OK to save the changes.
After this change, users opening Office documents from that library will be directed to the corresponding desktop application by default, provided they have the Office desktop apps installed.
For more information, please refer to Office URI Schemes | Microsoft Learn
I hope this information is helpful. Please follow the steps above and let me know if it works for you. If not, we can continue working together to resolve the issue.
If you found the response useful, please consider marking it as accepted, as this may help other community members who are looking for similar guidance.
Thank you for your patience and understanding. I look forward to continuing the conversation.
If you have extra questions about this answer, please click "Comment".
1 additional answer
  1. Eric 0 Reputation points
    2026-08-20T16:20:55.19+00:00
    When I use that URL:
    ms-excel:ofv|u|https://company.sharepoint.com/sites/Charts/Shared%20Documents/Chart.xlsx
    It takes me to Firefox, which prompts with the following: "Open the ms-excel link with Excel?" and gives me the option to either "Open link" or "Cancel." But I'm wondering if there's a way to bypass this extra step of having to click "Open Link" and just have the excel sheet open immediately in the desktop app. Any ideas?
