Camera is not working
Allan Donald 20 Reputation points
2026-06-26T00:49:13.4933333+00:00
I keep getting an error that "my camera might be covered". It is not. Further the error says that "I might need to slide a shutter near the camera, press a camera button on the keyboard or slide a camera switch on my device." There is not shutter or switch and there is no camera key on the keyboard. It is a Dell 14 plus.
Windows for home | Windows 11 | Apps
EmilyS_726 29,890 Reputation points Volunteer Moderator
2026-06-26T01:47:45.5233333+00:00
Allan, I looked at Dell 14 Plus, it does have a super thin slider cover right there, one you can push left or right.
1 additional answer
  1. Ivan B 124.4K Reputation points Independent Advisor
    2026-06-26T01:21:03.1966667+00:00
    Search for msinfo32.exe in the search bar, take a screenshot, and post it here so we can see the correct laptop model or desktop configuration.
    Do you have any third-party antivirus installed?
