How to fix rollback problem in nova client session.
Diana Jones 0 Reputation points
2026-06-25T10:57:53.7466667+00:00
So i have a bug related to azure connected machine agent , I am trying to install the msi of this by double clicking it but it reaches till 100 and rollback. Tried installing it through software centre of client by deploying the update from server to client but in that also it gets rollback. Not sure how to solve this issue.
Azure Arc
Azure Arc
A Microsoft cloud service that enables deployment of Azure services across hybrid and multicloud environments.
  1. Bharath Y P 10,610 Reputation points Microsoft External Staff Moderator
    2026-06-26T12:03:07.9+00:00
    Hello Diana Jones, You are attempting to install the Azure Connected Machine Agent (MSI):
    • Installation completes to 100%
    • Then performs a rollback
    • Issue occurs both Manual install (double-click MSI) and Software Center (SCCM) deployment
    This confirms the issue is not deployment method-related, but a machine-level failure during installation finalization (post-install actions).
    This behavior is consistent with a known Azure Connected Machine Agent installation issue combined with standard Windows Installer behavior:
    • The MSI appears to finish, but:
      • Final service configuration fails (Arc services)
      • MSI triggers automatic rollback
    • Common in:
      • Older agent versions (< v1.57)
      • Installations launched via double-click (non-elevated/UAC path)
    Known Arc Agent MSI Limitation
    Microsoft release notes state:
    This leads to:
    • Service registration failure (HIMDS / GCArcService / ExtensionService)
    • MSI completes UI but fails at final action → rollback
    MSI executes installation in steps, If any final action fails, installer Returns“Return value 3” or Triggers full rollback automatically.
    Use Proper Installation Method:
    Use elevated command:
    msiexec /i AzureConnectedMachineAgent.msi /l*v
    C:\Support\Logs\azcmagentsetup.log
    Ensures:
    • Proper privilege context
    • Prevents service configuration failure
    Use Latest Agent Version
    Download latest MSI https://learn.microsoft.com/en-us/azure/azure-arc/servers/agent-release-notes Recommended version ≥ 1.57 and Avoid older installer defects
    Check MSI Verbose Log (Mandatory for RCA):
    Open log: C:\Support\Logs\azcmagentsetup.log Search Return value 3, Check lines immediately above it That line = actual failure cause.
    Clean Existing/Corrupt Installation: Check if agent exists:
    Get-ItemProperty HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall |
    Where-Object {$_.DisplayName -like "*Connected Machine*"}
    If found msiexec /x {GUID} /quiet
    Then manually remove leftovers: C:\Program Files\AzureConnectedMachineAgent and C:\ProgramData\AzureConnectedMachineAgent, then Reboot and retry install
    Validate Service Creation Issues
    Check:
    • Event Viewer → System / Application logs
    • Errors related to:
      • GCArcService
        • HIMDS
    If timeout observed:
    HKLM\SYSTEM\CurrentControlSet\Control
    ServicesPipeTimeout = 120000
    Temporarily Disable Security Blocking
    • Antivirus / EDR (Defender, CrowdStrike, etc.)
    • Especially important in SCCM scenarios
    Microsoft explicitly recommends excluding install paths during agent installation https://learn.microsoft.com/en-us/azure/azure-arc/servers/agent-overview
    Hope this helps, If you have any question, please do let us know, thanks
  2. Alex Burlachenko 25,285 Reputation points MVP Volunteer Moderator
    2026-06-25T13:00:02.2033333+00:00
    hi & thx for sharing urs issue here at Q&A portal,
    An MSI rollback at 100% just means the install hit an error near the end and Windows Installer undid the changes. The UI won’t tell u why, so first get the MSI log. Run the installer from an elevated Command Prompt
    msiexec /i AzureConnectedMachineAgent.msi /L*v C:\Temp\AzureArcAgent-install.log
    Then search the log for
    Return value 3
    The lines just above that are usually the actual failure. Could be an old Arc agent install, pending reboot, blocked service creation, missing permissions, proxy/TLS issue, or endpoint security killing the install.
    Before retrying
    reboot
    Then check if an old agent is already installed
    sc query himds
    If it exists, uninstall the old Azure Connected Machine agent first from Apps & Features, reboot, then install the current MSI as admin. check %TEMP% and C:\Windows\Temp are writable
    enough free disk space AV/EDR isn’t blocking AzureConnectedMachineAgent.msi, azcmagent.exe, or service creation
    Windows Installer service is running the machine can reach Azure Arc endpoints if the installer gets as far as registration
    For Software Center, pull the client-side logs too C:\Windows\CCM\Logs\AppEnforce.log
    C:\Windows\CCM\Logs\ExecMgr.log
    AppEnforce.log normally shows the MSI exit code and exact command SCCM used.
    Don’t keep retrying blind. Post the section around Return value 3 from the verbose MSI log, plus the MSI exit code from AppEnforce.log, and the real cause should be visible.
    rgds,
    Alex
    If my answer was helpful pls mark it and additional thx if u follow me at Q&A portal
    and at my blog https://ctrlaltdel.blog/
