Failed to delete container due to ImmutabilityPolicy
Amir Yahav 40 Reputation points Microsoft Employee
2026-06-24T09:02:08.49+00:00
Why I could not delete the countainer despite 730 days have been past ?
Failed to delete 1 out of 1 blobs or directories: d=20240625: This operation is not permitted as the blob is immutable due to a policy. RequestId:8f4ece4a-e01e-000b-23b8-038f80000000 Time:2026-06-24T09:03:48.5627741ZUser's image
Azure Blob Storage
Azure Blob Storage
An Azure service that stores unstructured data in the cloud as blobs.
Praveen Bandaru 11,800 Reputation points Microsoft External Staff Moderator
2026-07-06T16:00:46.69+00:00
Hello Amir Yahav
Could you confirm whether you’re planning to delete just the containers or the entire storage account? Also, please check whether any policy is applied at the storage level.
If you want to delete your storage account, you can first move it to a Pay-As-You-Go subscription. Once the storage account is migrated, you may cancel that subscription, ensuring that the storage account will not incur any further charges
4 additional answers
  1. Senthil kumar 2,500 Reputation points
    2026-06-24T10:26:28.8666667+00:00
    Hi @Amir Yahav
    first check below settings.
    1.
    Container → Settings → Versions
    You must delete:
    Blob versions
    Snapshots
    Soft-deleted blobs
    Soft-deleted versions
    2.
    Storage Account → Data Protection
    Blob soft delete
    Version soft delete
    3.
    Container → Immutability → Legal Holds
    If any exist, remove them.
    4.
    check Policy State: is Locked -if locked remove that.
    check again Blob is immutable due to a policy.
    5,
    Blob versions exist? Any version blocks deletion
    Snapshots exist? Snapshots are immutable too
    Soft delete enabled? Soft-deleted blobs still count
    Legal hold active? Blocks deletion even after retention
    Policy still locked? Normal — deletion allowed only after cleanup
    Thanks.
  2. Amir Yahav 40 Reputation points Microsoft Employee
    2026-06-24T13:03:13.8066667+00:00
    1. I don't see the version:
    2. Nothing here to change :
    3. Delete option is dimmed.
    4. How to remove locked ?
    Please open a case since it's a complex problems that can't be resolved through the Q&A platform.
    I prefer that someone will call me by teams.
  3. Amir Yahav 40 Reputation points Microsoft Employee
    2026-07-01T10:53:44.8433333+00:00
    My problem requires a support ticket as all the settings are ok.
    Please create a support ticket on my behalf.
    Thanks Amir
  4. Deleted
