WinSxS Component Cleanup Metrics
Adin Mohhamed 40 Reputation points
2026-06-24T03:15:07.5866667+00:00
Our remote endpoints only have 256GB solid-state drives, and Windows updates are leaving gigabytes of old files in the component store. If I run dism /online /cleanup-image /analyzecomponentstore via a remote script, what metric tells me whether a full component cleanup will actually reclaim significant disk space? Any advice? Thank in advance.
Windows for business | Windows 365 Enterprise
Harry Phan 32,835 Reputation points Independent Advisor
2026-06-24T03:48:22.04+00:00
Hi Adin,
What you’re looking for in the dism /online /cleanup-image /analyzecomponentstore output is the “Component Store Cleanup Recommended” flag and the size reported under “Cache and Temporary Data” and “Backup and Disabled Features”. If “Cleanup Recommended” shows Yes, that’s Microsoft’s own indicator that running /startcomponentcleanup will reclaim meaningful space.
In practice, the biggest reclaim comes when “Backup and Disabled Features” is several GB, since that represents superseded updates still retained for rollback. If that section is small (for example, a few hundred MB), the cleanup won’t give you much back even if recommended.
Also note that /startcomponentcleanup alone won’t remove all old payloads; adding /resetbase will significantly reduce size but permanently removes the ability to uninstall existing updates. This is safe for stable endpoints but should be avoided on machines where rollback is required.
For remote execution, focus on parsing that single “Cleanup Recommended” value plus the reported reclaimable sizes, and only trigger cleanup when you consistently see multi‑GB reclaim potential to avoid unnecessary disk churn on SSDs.
Harry.
0 additional answers
