Follow these steps on Windows 11 to add both wireless printers:
- Make sure each printer is turned on and connected to Wi‑Fi
- On each printer, turn on the wireless/Wi‑Fi option (often shown with a blue wireless icon).
- Connect the printer to the same wireless network that the laptop is using (check the printer’s screen/menu for Wi‑Fi settings).
- If needed, run the printer’s wireless connectivity test from its menu to confirm it is connected.
- Check that the laptop is on the same network
- Connect the laptop to the same Wi‑Fi network name (SSID) that the printers are using.
- Add the printers in Windows 11
- Select Start > Settings > Bluetooth & devices > Printers & scanners.
- In Printers & scanners, check if the HP and Canon printers are already listed.
- If they are not listed, next to Add a printer or scanner, select Add device.
- Wait while Windows searches for nearby printers. When the HP or Canon printer appears, select Add device next to it.
- If Windows does not find the printers automatically
- In Bluetooth & devices > Printers & scanners, select Add device.
- When the search finishes, select Add manually (or The printer that I want isn’t listed / Add a new device manually).
- In the Add Printer window, choose the option that best matches the situation and follow the on‑screen steps.
- If the printers still do not appear
- Power cycle each printer: turn it off, unplug for 30 seconds, plug back in, and turn it on again.
- Confirm Wi‑Fi is enabled on the printers and that they are on the same network as the laptop.
- On the laptop, go back to Settings > Bluetooth & devices > Printers & scanners and select Add device again.
- Reinstall a printer that partially installed but will not work
- Go to Start > Settings > Bluetooth & devices > Printers & scanners.
- Select the HP or Canon printer (if listed) and choose Remove; confirm.
- Still in Printers & scanners, select Add device and wait for Windows to find the printer again, then select Add device.
If the printers install but do not print, print a test page from Printers & scanners and, if needed, check the HP or Canon support site for the latest drivers for each model.
