Error code: 400 when running General purpose Fluency evaluators
Justin Obanor 40 Reputation points
2026-06-22T19:13:37.83+00:00
Using the sample sample_fluency.py from azure-sdk-for-python at sdk/ai/azure-ai-projects/samples/evaluations/agentic_evaluators/sample_fluency.py, client.evals.create() succeeds but client.evals.runs.create() fails with:
BadRequestError: Error code: 400 - {'error': {'code': 'UserError', 'severity': None, 'message': 'The action cannnot be finished with reason Forbidden', 'messageFormat': 'The action cannnot be finished with reason {error}', 'messageParameters': {'error': 'Forbidden'}, 'referenceCode': None, 'detailsUri': None, 'target': None, 'details': [], 'innerError': {'code': 'UnauthorizedUserAction', 'innerError': None}, 'debugInfo': None, 'additionalInfo': None}, 'correlation': {'operation': 'e9a6cfb5f254b4298cc505acf31ed58c', 'request': '57fc69d1782fbf76'}, 'environment': 'eastus2', 'location': 'eastus2', 'time': '2026-06-22T18:35:59.0328447+00:00', 'componentName': 'raisvc', 'statusCode': 400}
The failure occurs only when creating the evaluation run.
The identity executing the code has the Foundry User role assigned on the Azure AI Foundry resource. I also assigned Foundry User to the project managed identity on the project level.
Inference works successfully using:
client.chat.completions.create(...)
with the same project and model deployment.
Is there additional RBAC required specifically for Evaluation Runs? Or any thing else that might be cauing the RequestError
Microsoft Foundry
Microsoft Foundry
A unified Azure platform for creating and managing AI models, agents, and applications with built‑in enterprise security, monitoring, and governance
Anshika Varshney 15,625 Reputation points Microsoft External Staff Moderator
2026-06-22T20:13:18.21+00:00
Hello @Justin Obanor
Based on the error details and Microsoft's documentation, the issue is likely network restrictions on your Azure AI Foundry account, not missing RBACroles.
Primary Cause: Network Restrictions Blocking raisvc
The error mentions raisvc (the evaluation backend service) and shows "Forbidden" - Microsoft has confirmed this exact issue occurs when the Foundry account uses Selected Networks network restrictions: [learn.microsoft]
  • Evaluation works when networkAcls.defaultAction = Allow
  • Evaluation fails when networkAcls.defaultAction = Deny (even with bypass = AzureServices)
The evaluation backend service cannot reach your restricted resources, even though inference works (your direct chat.completions.create call uses a different path).
Solution Steps
1. Check Network Configuration
bash
az cognitive services account show \
  --resource-group <your-resource-group> \
  --name <your-foundry-account-name> \
  --query "networkAcls"
2. Temporary Test: Enable Public Access
Temporarily set defaultAction to Allow to confirm this is the issue:
bash
az cognitive services account update \
  --bypass AzureServices \
  --default-action Allow
If evaluations work after this, network restrictions are confirmed as the cause.
3. Permanent Fix: Add Required Service Endpoints
Instead of fully disabling restrictions, add the evaluation service to your permitted networks:
  • Find the evaluation backend service endpoint
  • Add it to your network ACLs' allowed IPs/vnets
  • Or use a private endpoint configuration for evaluations
Secondary Checks (if network isn't the issue)
RBAC Requirements for Evaluation Runs:
While Foundry User should work, verify these minimum roles on the project:
  • Azure AI Foundry User (you have this)
  • Cognitive Services OpenAI User (if using Azure OpenAI)
  • Storage Blob Data Contributor on the storage account (for Entra ID auth)
Storage Account Configuration:
If using Entra ID authentication for storage:
bash
# Verify managed identity has Storage Blob Data Contributor
The storage account must also have publicNetworkAccess = Enabled.
Start with the network restriction check, this matches your exact error pattern (create succeeds, runs.create fails with raisvc/Forbidden) and is the most common cause per Microsoft's recent reports.
I Hope this helps. Do let me know if you have any further queries.
Thankyou!
1 additional answer
  1. Alex Burlachenko 25,290 Reputation points MVP Volunteer Moderator
    2026-06-25T12:07:17.4566667+00:00
    hi Justin Obanor & thx for sharing urs issue here at Q&A portal,
    inference is allowed, but the eval runtime path is blocked.
    client.evals.create() only creates the eval definition. client.evals.runs.create() actually kicks off the evaluator job, and that can hit extra Foundry/RAI service permissions behind the scenes. The clue is componentName: raisvc + UnauthorizedUserAction.
    Foundry User may be enough for normal project usage/inference, but eval runs can need broader project/resource perms, esp if the run has to read data, access model deployment, write eval outputs, or call RAI/evaluation services.
    Try to do a quick test give the executing identity Azure AI Developer on the project or Foundry resource, not only Foundry User, then retry. If it works, u have the answer eval runs need more than the current role grants. https://learn.microsoft.com/en-us/azure/ai-foundry/concepts/rbac-azure-ai-foundry Also make sure the project managed identity has access to whatever the eval run uses: model deployment, storage/data asset, connection, and any workspace/project resources. Inference working from the client doesn’t prove the service-side eval job identity can access those deps. Since the error is thrown by raisvc, I’d include the operation/request IDs in a support ticket if RBAC change doesn’t fix it operation: e9a6cfb5f254b4298cc505acf31ed58c & request: 57fc69d1782fbf76
    My guess not a bad sample file. More likely eval run authorization is stricter than chat inference, and the backend is returning a bad 400 wrapper around what is really a forbidden action.
    rgds,
    Alex
    If my answer was helpful pls mark it and additional thx if u follow me at Q&A portal
    and at my blog https://ctrlaltdel.blog/
