Troubleshooting website display or functionality issues in Edge on Windows 11
I was on a copy and paste symbol on website, but it shows with a blank square, and I am having issues with it.
Hi! Let me help you.
Can you please take a screenshot of the issue you are having and paste it here? Thanks!
AI answer
Blank squares usually mean the font on the device does not support the symbol that was copied from the website. When a character is displayed using a font that does not contain that character, Windows shows a default “not defined” glyph, which is typically a square box.
On Windows 10/11, some fonts for certain languages/scripts are not installed by default and are instead in optional font packages. If the symbol uses one of those scripts and the required font is missing, the browser (Microsoft Edge) will show squares instead of the intended symbol.
To fix this on Windows 11 (similar steps as Windows 10):
After installing the relevant optional font feature, restart Edge and test the website again. If the site or app still shows squares, the site may be using a font or character that is not supported, in which case contacting the site/app developer is recommended.
I don't they have Apps & Features
