Replying to or forwarding an email does not include the original message in the email body in legacy Outlook for Mac
Leslie Marsh 30 Reputation points
2026-06-22T12:01:18.1966667+00:00
Since updating to version 16.110, replying to or forwarding an email does not include the original message in the email body in legacy Outlook for Mac. Apparently this is a known issue and a "work-around" is to switch to the new Outlook for Mac. However, in new Outlook for Mac, it puts my signature into the body of the email I'm responding to. So, neither version is working correctly. Anyone know how to fix this?
Jayden-P 26,280 Reputation points Microsoft External Staff Moderator
2026-06-22T12:36:15.57+00:00
Update: 24/06/2026
Microsoft has rolled out version 16.110.1 on Current Channel. Please update your device to this version to fix the issue.
Hi @Leslie Marsh
Thanks for reporting this issue. Microsoft is aware and actively investigating this behavior.
Replying to or forwarding an email does not include the original message in the email body in legac…
I have tested on previous version such as 16.109.3, and this behavior does not occur. Therefore, you may consider reverting to version 16.109.3 or older. This can be done by removing the current Outlook version and installing version 16.109.3 via Update history for Office for Mac - Office release notes | Microsoft Learn
After that, turn off automatic updates for Legacy Outlook for Mac by going to Help > Check for Updates > unchecking Automatically keep Microsoft apps up to date.
Additionally, if you want to prevent new Outlook to automatically insert signature when you reply, please go to Settings > Signatures > Set default signatures for replies and forward to None.
I apologize for the inconvenience this might have cause to your workflow, please revert back to previous version or turn off signatures when reply as a temporary workaround.
I will keep you updated if there's a fix for this. Thank you for your understanding and patience.
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
1 additional answer
  1. Burak VAROL 946 Reputation points
    2026-06-22T12:44:04.0333333+00:00
    Hi @Leslie Marsh ,
    There are several threads about this known issue, and the workarounds suggested by @Jayden-P are currently the only reliable options until a permanent fix is rolled out.
    Regards,
    Burak V.
