Managing tabs, address bar, and search settings in Edge on Windows 11
Why does Microsoft seem to do the opposite of what users want instead of listening to them? Many people use the sidebar because it saves space and keeps important things like emails, Teams, and other tools easily accessible without having to switch tabs. Pushing an unnecessary Copilot feature under the excuse of “simplifying the browser” feels misleading.
Copilot isn’t what causes Edge to slow down it’s the sidebar? lol. At Microsoft, are people even using their own products? It doesn’t seem so, as just opening their presentations shows many of them using other browsers instead of Edge.
Why is it so hard to let users choose whether they want the sidebar or not?
AI answer
The Edge sidebar behavior is changing because Microsoft is retiring the current sidebar app list (also called the App Tower) as part of a broader simplification of Edge, while keeping Copilot and the side pane.
From the available information:
HubsSidebarEnabled policy controls whether the sidebar is allowed or blocked. Disabling it blocks all sidebar apps and removes access to the Discover app.EdgeSidebarCustomizeEnabled controls whether users can customize the sidebar (add/delete apps).EdgeOpenInSidebarEnabled controls whether users can open websites or apps in the sidebar via Settings and more > Open in sidebar.edge://settings/sidebar (or Settings and more > Settings > Sidebar).There is no documented way to revert the retirement of the sidebar app list once the change reaches a given Edge build. For managed environments, the closest available control is via the Edge policies that enable/disable the sidebar and its customization; for consumer environments, the change is a product decision and is being rolled out gradually.
Hello, thank you for reaching out to Microsoft Q&A.
I understand the use of having this feature in the Microsoft Edge web browser. However, since the feature has been fully retired by Microsoft, your feedback will be important to help drive future improvements.
I recommend submitting your feedback directly from within the Microsoft Edge browser, where it can be shared straight with the developer team. To submit your feedback, click the three horizontal dots in the upper-right corner of Edge, select Help and feedback, and then click Send feedback.
Reference - Sidebar app list is being retired in Microsoft Edge
