Issues distributing pages in Class Notebooks
Karen Daffy 25 Reputation points
2026-06-21T03:18:47.6266667+00:00
Since last week I have had trouble distributing work to students using ClassNotebook. I have tried through the Desktop App, Web Browser and Teams. They all queue up the pages and the just hang as Waiting to start. I have tried in a number of Notebooks and the same issue every time. I have tried manual synchs as suggested in troubleshooting and opening and closing.
Are there any suggestions to help?
Microsoft 365 and Office | OneNote | For education | Windows
2026-06-21T04:10:59.5766667+00:00
Hi @Karen Daffy,
Thank you so much for taking the time to share this.
I’d really like to help as much as I can from my side, but first could I ask you a couple of quick things to better understand the situation:
  • Do you know if anyone else in your school or organization is experiencing the same issue, or does it seem to be happening only to you?
  • Also, could you try distributing a very simple test page, something without any attachments like PDFs or files, to just one or two students and see if that goes through normally?
From what you’ve described, and based on what I’m seeing so far, it doesn’t look like Microsoft has officially reported any known issue related to this behavior at the moment. Given that you’ve already tried across OneNote Desktop, the web version, and Teams, and even tested with multiple Class Notebooks, but all distribution jobs are stuck in a “Waiting to start” state, this does start to feel less like a local sync issue and more like something happening on the service or tenant side. Since Class Notebook distribution runs in the background and relies on backend processing, if none of the jobs are kicking off at all, that’s often a sign it may need deeper investigation.
As this is a user-to-user support forum, I’m also just another user here, so I don’t have access to the internal tools or permissions needed to directly resolve something at that level.
Because of that, I would strongly recommend reaching out to your school’s IT admin and asking them to open a support ticket with Microsoft.
User's image User's image
Once a ticket is created, a Microsoft support engineer can take a closer look at your environment, check backend processes, and run more advanced diagnostics. If needed, they can also escalate it to a specialized team for further investigation.
I’ll also keep an eye out to see if there are similar reports from others, just in case this turns out to be more widespread.
If you do receive any updates or find anything new, feel free to come back and share, it could really help others in a similar situation as well.
Thank you so much for your understanding.
0 additional answers
