Redeemed second product key on wrong computer
Michael Wilser 20 Reputation points
2026-06-20T15:26:15.57+00:00
I purchased two copies of MS Office Home 2024 for Mac via Amazon. Yesterday I redeemed one key on my computer; all went well. This morning, I inadvertently redeemed the second key on the same computer, when I actually had intended to install it on my wife's computer. How do I remedy this?
Microsoft 365 and Office | Install, redeem, activate | For home | MacOS
Xavier-D 13,390 Reputation points Microsoft External Staff Moderator
2026-06-23T04:40:34.0933333+00:00
Hello Michael Wilser
Was the answer provided by AI able to help you solve this issue?
If not, then I would like to suggest an additional solution:
Because the second key was redeemed to the wrong Microsoft account and you specifically need it associated with your wife’s Microsoft account instead, that usually cannot be fixed from the device itself.
In that case, contact Microsoft Support and ask for further assistance about this issue. You can start here:
Please note that this is a user-to-user support forum. Moderators and contributors, including external Microsoft employees, are not allowed to directly interfere with Microsoft product features or access back-end systems. Our role is limited solely to providing technical guidance on reported incidents, requests, or ideas.
  1. Open a website link - Contact - Microsoft Support
  2. In the box below "We're here to help", type Microsoft 365, click "Get Help", and then click "Contact Support" below.
  3. In this section, you will need to sign in to your Microsoft account.
  4. Select "Microsoft 365 and Office" under Products & Services, select "Technical Support" as the category, and click to confirm
  5. You can select " Chat with a support agent in your web browser " to access the chat window.
I hope this information help, have a nice day.
1 additional answer
    2026-06-20T15:26:34.4966667+00:00
    Each Office Home 2024 product key can be redeemed only once and then is permanently tied to the Microsoft account used at redemption, not to a specific computer.
    Since the second key was redeemed on the same Microsoft account, it is now associated with that account. To use it on the intended (wife’s) Mac, install and activate from that same account on her computer:
    1. On the wife’s Mac, open a browser and go to the Microsoft account Services & subscriptions page: https://account.microsoft.com/services.
    2. Sign in with the same Microsoft account that was used to redeem both Office Home 2024 keys.
    3. Under Services & subscriptions, locate the second Office Home 2024 entry.
    4. Select Install next to that Office Home 2024 and download/install Office on her Mac.
    5. After installation, open an Office app (for example, Word) and, if prompted, sign in with the same Microsoft account to activate.
    There is no need to redeem the product key again or move it between computers; the key’s job is done once it is redeemed to the Microsoft account.
    If the wrong Microsoft account was used when redeeming, check other Microsoft accounts owned and sign in to each at the Services & subscriptions page until the Office Home 2024 license is found.
