Recovery USB Failing
LGLDSR73-6492 1,480 Reputation points
2026-06-19T16:59:48.4933333+00:00
I downloaded a Media Creation Tool to create a Recovery USB. After that was downloaded and written to the USB, I went to test it.
While it allows me to select "Repair My PC", it keeps looping back to what you see in the attached screen capture, even though I select 'Repair My PC'.
O/S is Windows 11 Home, 25H2.
Any idea what is going on?
Thank you,
Lyman
Gas
Windows for home | Other | Recovery and backup
SD - IA 179.8K Reputation points Independent Advisor
2026-06-25T15:29:22.49+00:00
Thank you for letting me know - it will surely help other users.
2026-06-24T15:50:54.3666667+00:00
It was not an HP Recovery Tool. HP only informed me that they no longer make a BIOS with Legacy support. Therefore I had to create a bootable USB for UEFI support with Rufus, format it with GPT. It works fine and I have access to the MS Tools I (hopefully will not) need.
Best,
LGLDSR71
6 additional answers
  1. SD - IA 179.8K Reputation points Independent Advisor
    2026-06-24T15:40:23.4966667+00:00
    Apologies for the delay in response.
    Please advise as to how I should continue creating a bootable recovery USB to access the Win-11 Recovery Tools.
    The media creation Tool https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f-aa6f-40c3b507420d will automatically pick up the configuration and create a Media accordingly. The newest Installation media DOES NOT require to disable Secure boot.
    I hope this information helps. If you have any more questions, don't hesitate to reach out.
    Otherwise, if your problem is resolved, please take a moment to rate the answer. Wishing you good luck!
  2. LGLDSR73-6492 1,480 Reputation points
    2026-06-24T15:43:19.2666667+00:00
    I had to create a UEFI bootable USB with Rufus. HP no longer makes a BIOS with Legacy Support. You do however need to disable Secure boot.
  3. SD - IA 179.8K Reputation points Independent Advisor
    2026-06-24T15:46:44.74+00:00
    I wouldn't also go with HP recovery tool since it installs a lot of bloatware apps. Rufus is fine and an open source tool, but the Media Creation tool from Microsoft which was linked on the page is the best one!
