Recovery USB Failing
LGLDSR73-6492 1,480 Reputation points
2026-06-19T16:59:48.4933333+00:00
I downloaded a Media Creation Tool to create a Recovery USB. After that was downloaded and written to the USB, I went to test it.
While it allows me to select "Repair My PC", it keeps looping back to what you see in the attached screen capture, even though I select 'Repair My PC'.
O/S is Windows 11 Home, 25H2.
Any idea what is going on?
Thank you,
Lyman
Gas
Windows for home | Other | Recovery and backup
SD - IA 179.8K Reputation points Independent Advisor
2026-06-25T15:29:22.49+00:00
Thank you for letting me know - it will surely help other users.
2026-06-24T15:50:54.3666667+00:00
It was not an HP Recovery Tool. HP only informed me that they no longer make a BIOS with Legacy support. Therefore I had to create a bootable USB for UEFI support with Rufus, format it with GPT. It works fine and I have access to the MS Tools I (hopefully will not) need.
Best,
LGLDSR71
6 additional answers
  1. LGLDSR73-6492 1,480 Reputation points
    2026-06-23T17:01:44.18+00:00
    Per HP:
    • On many newer HP laptops, especially AMD-based models like yours, the BIOS may not include a “Legacy Mode” option at all because they are designed to boot only in UEFI mode. That means bootable USB drives must be created with UEFI support enabled.
    Please advise as to how I should continue creating a bootable recovery USB to access the Win-11 Recovery Tools.
    Thank you,
    LGLDSR73
  2. SD - IA 179.8K Reputation points Independent Advisor
    2026-06-20T02:38:08.1933333+00:00
    Thanks a lot! Please do keep me posted. If this helps resolve your issue, kindly remember to accept the answer. :)
  3. SD - IA 179.8K Reputation points Independent Advisor
    2026-06-19T17:38:33.2266667+00:00
    The common cause of this is the media not being created properly.
    Could you try making the same again?
    https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f-aa6f-40c3b507420d
    Also, in BIOS ensure it is updated, and the boot tab has Legacy Boot disabled.
    I’m eager to hear back and work together to find a solution.
