Installing or updating Microsoft Edge on Windows 11
O Microsoft edge não abre, e não aparece na lista de programas instalados já tentei reinstalar mas não abre
AI answer
Siga estes passos em ordem até o Edge voltar a funcionar:
Se, após todos esses passos, o Edge continuar sem abrir e não aparecer na lista de aplicativos, use outro navegador para baixar novamente o instalador em https://www.microsoft.com/edge e tente reinstalar mais uma vez.
Greetings!
This is Tin, sorry to hear that you're experiencing MS Edge issue. May I know when did the issue start? Is there any changes made before you got this issue?
Kindly send the version or build of your Windows (Please press Windows key+R and type winver and hit enter)
Since you've mentioned that it's not showing under installed apps, please try to shutdown your device to complete the uninstallation in case it's still under process and then try to reinstall it.
Please check if the issue persists.
If yes, please click Start menu and type CMD, right click on it and choose Run as Admin, please paste the command below and hit enter.
DISM.exe /Online /Cleanup-image /Scanhealth
DISM.exe /Online /Cleanup-image /Restorehealth
Please wait for it to finish and repair the system files.
Once done, please paste the command below and hit enter.
sfc /scannow
Please wait to finish.
Check if the issue persists.
Please let me know how it goes.
Tin
Please try to perform an in place upgrade. In place upgrade will install the new features or updates of Windows it will also fix corrupted system files. Kindly check the steps below:
Video on how to perform in place upgrade:
https://www.youtube.com/watch?v=CAOwN68AInE&feature=youtu.be
Please go to https://www.microsoft.com/en-us/software-download/windows11
Look for Download Windows 11 Disk Image and select Windows 11 (multi-edition ISO)
This may take sometime depends on your connection or the performance of your device.
Please let me know the result. I'll be happy to assist you all the way until it's resolved.
Thank you,
Christine L
Standard Disclaimer: Youtube.com link is a non-Microsoft website. The pages appear to be providing accurate, safe information. Watch out for ads on the sites that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the sites before you decide to download and install it.
