How do I get rid of Edge News headlines?
2026-06-19T01:01:05.0266667+00:00
The browser keeps defaulting to showing all this crap and now I cannot work out how to turn it off any more. Can you please make it easy to turn off the clickbait. No one likes it.
Microsoft Edge | Website issues | Windows 11
Marcin Policht 109.5K Reputation points MVP Volunteer Moderator
2026-06-19T01:57:14.77+00:00
Open a New Tab, click the Gear (Settings) icon in the top right corner, set the Show content to Off
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
1 additional answer
  1. Kayece Jan Mae Amizola 16,680 Reputation points Independent Advisor
    2026-06-19T01:49:41.26+00:00
    Are you referring to this headline?
    If so, you can turn these tips off by going to the customize page, then turn the copilot tips off, or you can go to each headline tip, and you can see three dots, click on it, then turn off copilot tips.
    If you do not want this, please click the " Turn off Copilot new tab page" to go back to the default theme.
    If it is a different issue, please screenshot and upload it here to know more details regarding the headline.
    I look forward to your response.
    Stay Safe!
