Excel vba public variable not storing in do loop after update
Domenic Moscato 25 Reputation points
2026-06-18T13:42:59.2766667+00:00
For the below VBA code. We've been using this code for several years. Presently, the (below) code is not storing the Mrow data or (it forgets the value of the SEC-ID line) as soon as the code executes it leaves the SEC-ID line and the variable is emptied. This wasn't occurring before the most recent update. Present Version 2508 (Build 19127.20646). Would you know what update would have caused this issue?
Mrow = 9
Do
Mrow = Mrow
scr.moveTo Mrow, 2, 1
SecID = Trim(scr.Area(Mrow, 4, Mrow, 12))
If SecID = "" Then
   GoTo SkipTran
Else
   Call SendKeysWaitX(scr, "<Enter>")  ' goes to the details screen
End If
Developer technologies | Visual Basic for Applications
Nancy Vo (WICLOUD CORPORATION) 8,160 Reputation points Microsoft External Staff Moderator
2026-06-19T04:13:33.8666667+00:00
Hello @Domenic Moscato ,
Thanks for your question.
Imagine Mrow as a sticky note holding the number 9. The code uses it to find drawer 9 on your screen and read the SecID label. However, due to a recent Excel update, the code accidentally erases this sticky note right after reading it, which breaks the rest of the process.
I recommend passing the code a "photocopy" of the sticky note instead. This keeps the original Mrow value safe. You can refer to these two options:
  1. Putting extra parentheses around the word Mrow forces Excel to make a quick photocopy. Change your SecID line to exactly this:
SecID = Trim(scr.Area((Mrow), 4, (Mrow), 12))
  1. You can create an actual temporary copy just before the step that fails. Update your code to look exactly like this:
Mrow = Mrow
Dim TempRow As Integer
TempRow = Mrow
SecID = Trim(scr.Area(TempRow, 4, TempRow, 12))
If SecID = "" Then
Please try these options and let me know the results. I would be happy to investigate further if needed.
I hope this addresses your question. If this response was helpful, please consider following the guidance to provide feedback.
1 additional answer
  1. Prathamesh Mandage 0 Reputation points
    2026-06-19T03:31:16.5333333+00:00
    becomes Empty after SendKeysWaitX(scr,"<Enter>") executes and returns to the loop.
    A stronger answer for the post would be:
    Answer:
    This probably is not a VBA Public variable problem or a recent Office update changing variable persistence. From the screenshots, Mrow remains 9, but the expression:
    starts returning Empty.
    The more likely issue is that:
    SendKeysWaitX(scr,"<Enter>") changes the active screen/state
    scr gets refreshed/recreated
    scr.Area(...) no longer points to the same object/data after returning
    Try storing the value before the screen navigation:
    Dim TempSecID As String
    TempSecID = CStr(Trim(scr.Area(Mrow, 4, Mrow, 12)))
    SecID = TempSecID
    Also add debug output:
    Debug.Print "Mrow = " & Mrow
    Debug.Print "SecID before Enter = " & SecID
    Call SendKeysWaitX(scr,"<Enter>")
    Debug.Print "SecID after Enter = " & SecID
    If SecID disappears only after SendKeysWaitX, then the problem is likely object state refresh or screen focus changes rather than a Microsoft update changing Public variables.
    I would investigate scr and SendKeysWaitX() behavior first.
