Support Needed for RCA about SQL DB Connection Issues Caused outage
Raja Yashwanth Reddy Gunda 0 Reputation points Microsoft External Staff
2026-06-18T03:33:50.17+00:00
Support Needed for RCA about SQL DB Connection Issues Caused outage on 04/28
SQL Server on Azure Virtual Machines
  1. Ravi Kiran Pagidi 170 Reputation points
    2026-06-20T12:58:38.5433333+00:00
    Hi Raja,
    For an official RCA of an Azure SQL Database connection outage, Microsoft Q&A users will not be able to check backend telemetry or confirm the platform-side root cause. You would need to check Azure Service Health / Resource Health first, and if the outage is not clearly explained there, open an Azure support request.
    Please check:
    1. Azure Portal > Service Health Look for any Azure SQL Database service issues around 04/28 in the affected region.
    Azure SQL Database > Resource Health Check whether the database shows Available, Degraded, or Unavailable during the outage window.
    Azure Monitor metrics / logs Review failed connections, DTU/vCore utilization, CPU, workers, sessions, deadlocks, throttling, and firewall/network changes during the same time.
    Application logs Capture the exact SQL error numbers/messages, timestamps in UTC, client IP/app server, and connection retry behavior.
    If you need a formal RCA for business/audit purposes, open a Microsoft support request and include:
    Subscription ID
    Server/database name
    Region
    Exact outage start/end time in UTC
    Error messages/error numbers
    Resource Health screenshots
    Application connection logs
    Docs:
    Azure SQL connectivity troubleshooting: https://learn.microsoft.com/en-us/azure/azure-sql/database/troubleshoot-common-errors-issues
    Use Resource Health for Azure SQL connectivity issues: https://learn.microsoft.com/en-us/azure/azure-sql/database/resource-health-to-troubleshoot-connectivity
    Azure Service Health overview: https://learn.microsoft.com/en-us/azure/service-health/service-health-portal-update
    Create Azure support request: https://learn.microsoft.com/en-us/azure/azure-portal/supportability/how-to-create-azure-support-request
